Need Help:Looking to get a '95 GSR(did search)
Ok...I am "new" to this site so keep the "go search noob" to yourself. I found a '95 Gsr w/150k miles and its going for 4g's. Ok....That is definetely how much I have and I cant save for something better. Anyway...I need to know what is the compression on the cylinders supposed to read? I'm gonna take a compression kit over to do it myself and I need to know the specs. Also, the dude is running an open header
so its throwing a code. What I wanna know, is the code because of that? Any help will be much appreciated! Thanks in advance.
Not sure about the compression.
As far as the code goes: Probably. In '95 the High-temp O2 sensor was in the cat before the actual catalysts. If he's running open headers chances are pretty good that there is no sensor there anymore and it's throwing a code (and running rich, and a couple other things). I'd still run the code though just to be sure that nothing else is wrong.
in my 95 gsr i got 200 across all 4 and thats with 152k on it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P1mpSlap »</TD></TR><TR><TD CLASS="quote">I'd say about 240 or so
you sure a gsr is stock 240? if so now i feel bad, maby its time for a rebuild
Image from the helms manuel >>>
It says right under the hood on the sticker what the compression should be . There is an article on http://www.team-integra.net that tells all about it .
Nominal is 270
Minimal is 135 with a variance of no more than 28 per cylinder
It says right under the hood on the sticker what the compression should be . There is an article on http://www.team-integra.net that tells all about it .Nominal is 270
dam now i feel bad. looks like i better look in to new rings and some head work. can i just chnage the rings on my pistons that are in there? or can i swap some CTR pistions in there with the stock sleves?
Ok...this is good info. Have any of you done a compression check yourselves? I'm gonna attempt to do it by the instruction of my mechanic (who cant go). Thanks! I was planning on doing a rebuild on the head anyway though.
