Please help! Oil line issue *pics*
Old Jan 7, 2004 | 08:58 PM
Hoosier Daddy's Avatar
Default Please help! Oil line issue *pics*
Having a little bit of an issue with my oil line. Just put the motor in the car and set everything up. I screwed the fitting on crooked like an idiot, so there's an oil leak. This is what I get for 14 straight hours of work with no food/rest
Anyway, I don't think I'm gonna be able to get the same type of return line. My downpipe is the way, and doesn't let it screw on straight. How curved can my return line be? Also, how long can it be? Right now it's very short and straight. It may work to go around the downpipe. I tried to take some pics but it was very dark, and I was finally clean so I kinda just stuck my camera in there and took pics until some decent ones came out.
Any help/suggestions/pics of other return lines would be greatly appreciated!
Going from the turbo to the oil pan, very tight fit!
Similar pic, but easier to see that I can't move it any more to the left so that it lines up with the fitting correctly (it's screwed on crooked). The red part hits the downpipe.
Different angle. A little easier to see how it's crooked (that's silicon on the threads had to drive it home (a few blocks away and figured it couldn't hurt).
Top down view:
Just another shot:
Old Jan 7, 2004 | 09:03 PM
bretx0r's Avatar
Default Re: Please help! Oil line issue *pics* (Hoosier Daddy)
you could prolly try and route it around the downpipe with a longer line but thats the best solution i can think of pretty much if it stays going at a downwards angle it doesnt really matter how long it is
Old Jan 7, 2004 | 09:33 PM
Del_Slowest's Avatar
Default Re: Please help! Oil line issue *pics* (bretx0r)
use a smaller line, i'm using a 8an
Old Jan 7, 2004 | 09:57 PM
simple4012's Avatar
New User
go to an exaust shop and have them fix your downpipe and get a new stainless line if that one is messed up. was this a kit or a pieced together setup?
Old Jan 7, 2004 | 10:26 PM
rondigs's Avatar
Default Re: Please help! Oil line issue *pics* (simple4012)
Contact Flamenco-T (stan) and see if he can help. Im sure he can come up with a resolution.
LSTurbo23
Feb 14, 2010 05:00 PM
Boosted_Coupe
May 20, 2007 12:15 PM
highmilehatch
Sep 28, 2003 07:52 PM
T25 civic
Oct 15, 2002 12:52 PM
