Oil restrictor problem..need help!
Old Feb 13, 2010 | 03:57 PM
LSTurbo23's Avatar
Default Oil restrictor problem..need help!
Originally Posted by BlueShadow
Hey guys,
I had a question for those of you using the ATP restrictor. It says it's 1/8 NPT male and 1/8 NPT female on the other side. If that's so, why cant I get any of my 1/8" NPT fittings to screw into the female end? I've tried 5 different fittings and none of them go in. However the other ends on those 5 fittings are 3 AN, and the 3AN goes right into the female 1/8 NPT.
I can get the male 1/8 NPT into the restrictors female end, but it will only go in half a turn. Do I just need to bust out the pliers and wrenches and use my gorilla-like strength and tighten the crap out of them?
Thanks
i have that exact same problem^ i dont wanna buy a new oil line if i know theres some way my oil line will work..and i have the correct oil line this **** just doesnt go on..is there some sort of fitting i should get?
Old Feb 13, 2010 | 04:50 PM
welfarepc's Avatar
Default Re: Oil restrictor problem..need help!
take a picture
Old Feb 14, 2010 | 03:16 PM
LSTurbo23's Avatar
idk what a pics gonna solve..its a straight forward question..plus i have no pics and cant take pics right now
i mainly just want to know how others with oil restrictors had them fit their oil lines..because ive seen its a problem through my searches but ive found no answers
bump for some much needed help
Old Feb 14, 2010 | 05:00 PM
welfarepc's Avatar
a picture will most likely point out you are wrong about the threads on your fitting, and i can tell you what they actually are.
Hoosier Daddy
Jan 7, 2004 10:26 PM
FOrSfEd
Nov 21, 2003 07:39 PM
NuclearB18B
Jul 31, 2003 02:02 AM
T25 civic
Oct 15, 2002 12:52 PM
RATEDR
Jul 2, 2002 07:18 PM
