good non vtec cams?
Old Jan 7, 2004 | 03:50 PM
JdM_Eg_6's Avatar
Default good non vtec cams?
what cams should i use when running jdm ctr pistons oversized on my ls motor. I want to get as much power as possible? thanks!
Old Jan 7, 2004 | 04:35 PM
projectTeG's Avatar
crower 403 or 404s
Old Jan 7, 2004 | 04:39 PM
JdM_Eg_6's Avatar
Default Re: (projectTeG)
well i was debating between those two but i was just wondering if i was goin to go with the 404's will a good port and polished head, milled and crower valve springs and retainers. with my jdm ctr pistons will it work well and what kind of power should i be pushing out
Old Jan 7, 2004 | 06:47 PM
12secB18acivic's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by projectTeG &raquo;</TD></TR><TR><TD CLASS="quote">crower 403 or 404s</TD></TR></TABLE>
Old Jan 7, 2004 | 07:05 PM
91tegrals's Avatar
i have a set of jg 303s there a little bigger then the 404s and ill let them go for 175$ let me know if you want them trying to get some extra money for a turbo set up...
Old Jan 8, 2004 | 06:14 PM
JdM_Eg_6's Avatar
Default Re: (91tegrals)
will those go good with my set up????
set up:
B18b head-
with a wild port and polish job, crower stage 3 cams, crower springs and retainers, new valves, and a larger fuel pump with a 2 or 1 layer head gasket with 2 layer ill be pushing out about 11:7 compression and with the 1 layer ill be pushing 12. what does everybody think i should do to get max power (92 octane) should i mill my head at all since compression is already going to be high?
B18b block-
jdm ctr pistons .025 oversized, machined to my ls rods and balanced, and a machined crank
P.S. I will also be running a hondata stage 4 programed ecu
Old Jan 8, 2004 | 06:41 PM
JdM_Eg_6's Avatar
Default Re: (mini_me)
help needed!
Old Jan 8, 2004 | 07:17 PM
JdM_Eg_6's Avatar
bump!
Old Jan 9, 2004 | 11:34 AM
Project X's Avatar
Careful going for Crower 62404 or wilder with the JDM CTR pistons, 1 layer headgasket and milled head. The valves and pistons might slap. Make sure you clay or blueprint it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini_me &raquo;</TD></TR><TR><TD CLASS="quote">bump!</TD></TR></TABLE><TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mini_me &raquo;</TD></TR><TR><TD CLASS="quote">bump!</TD></TR></TABLE>
Old Jan 9, 2004 | 02:32 PM
RTE117's Avatar
i know a kid with 403', was skeptical at first, but they're nice
Old Jan 9, 2004 | 07:26 PM
JdM_Eg_6's Avatar
Default Re: (Project X)
thanks!
Old Jan 11, 2004 | 07:15 PM
91tegrals's Avatar
yeah you may want to clay youre pistons with cams that big just to be on the safe shide...
spags930
Apr 5, 2010 12:20 PM
Davidls
Feb 24, 2009 07:05 AM
Mixmasta
Jan 19, 2009 07:33 AM
CivicVX94
Jun 13, 2006 03:08 PM
b18vtecboi
Sep 21, 2004 12:27 AM
