insane idle now that its cold...any ideas?
Old Jan 7, 2004 | 11:44 AM
RedStarGsr's Avatar
Default insane idle now that its cold...any ideas?
hey guys, without having much luck in the search department (whats goin on with that anyway?)
when starting my car up in cold ohio weather today, my so called normal >1000k idle jumped all the way up to 3500 today... then after driving around for 5-10 mins it would lump from from 1000-3000 rapidly. Im not sure what would be causing this, all lines are hooked up and nothing has changed? My throttle body screw is backed almost all the way out, and i just dont understand why it would randomly go up that high because of the so called 'cold' weather. any idears?
Old Jan 7, 2004 | 12:00 PM
BROOD's Avatar
Default Re: insane idle now that its cold...any ideas? (RedStarGsr)
The actual cause can vary alot but in my case I had the same thing that was more pronounced in colder weather...it ended up being a fast idle valve. I adjusted it at fist which helped slightly but ended up replacing it.
Chillinit's Avatar
not sure..but maybe a vacuum leak?!..double check all hoses
Old Jan 7, 2004 | 12:01 PM
RedStarGsr's Avatar
Default Re: insane idle now that its cold...any ideas? (Chillinit)
br00d-- how exactly do you adjust the fitv? i bypassed it a whiel ago (when i thought 1000 was a high idle) and it just got worse...any insite would be great.
joelmatt89
15
Nov 4, 2009 05:27 PM
spock_rocker
Oct 17, 2007 08:11 AM
PWRDbyHseries
Oct 18, 2006 05:44 PM
jetlude
Aug 1, 2006 11:09 AM
