ecu question about socketing
Old Jan 6, 2004 | 03:06 PM
G U E C O's Avatar
Default ecu question about socketing
what IC socket do i need to socket my 5 speed p28 ecu (22 or 28 pins)? also if i jsut want to socket and chip my 5 speed p28 ecu do i need to get a different resistor?
Old Jan 6, 2004 | 03:42 PM
G U E C O's Avatar
up
Old Jan 6, 2004 | 05:43 PM
G U E C O's Avatar
come on
Old Jan 6, 2004 | 06:48 PM
evilxkid's Avatar
Default Re: ecu question about socketing (stock93cx)
you need 2 .1uf capasitors one 1k resistor one 28 pin socket and a 74hc373 ic. you can get it all at radio shack
Old Jan 6, 2004 | 10:22 PM
G U E C O's Avatar
where do i place the 2 .1uf capasitors and one 1k resistor?
Old Jan 7, 2004 | 09:27 AM
G U E C O's Avatar
ttt
Old Jan 7, 2004 | 12:32 PM
G U E C O's Avatar
bump
Old Jan 7, 2004 | 07:56 PM
G U E C O's Avatar
bump it up
Old Jan 8, 2004 | 07:17 AM
G U E C O's Avatar
none knows?
Old Jan 8, 2004 | 07:48 AM
SOHCwarrior's Avatar
Default Re: (stock93cx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by stock93cx &raquo;</TD></TR><TR><TD CLASS="quote">where do i place the 2 .1uf capasitors and one 1k resistor?</TD></TR></TABLE>
.1 uf caps at c52, c51
1-1.2k resistor at r54
and then connect j1 with just a spare piece of wire, cutting this later returns ecu to stock prog
Old Jan 8, 2004 | 08:29 AM
Dr Honda's Avatar
open up your ECU... it's all outlined in white, and the spots are marked.
or check out ECUcontrol.com. he has a writeup on how to do it.
Old Jan 8, 2004 | 11:54 AM
G U E C O's Avatar
thanks
Old Jan 9, 2004 | 06:00 PM
PHiZ's Avatar
Let us know how this goes
-PHiZ
Old Jan 9, 2004 | 07:28 PM
Maintenance's Avatar
Default Re: (SOHCwarrior)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHCwarrior &raquo;</TD></TR><TR><TD CLASS="quote">
and then connect j1 with just a spare piece of wire, cutting this later returns ecu to stock prog</TD></TR></TABLE>
correct i'm going to do it next week. Learn it from http://www.nitroburn.com/pgmfiwiki/ and http://www.ecucontrol.com/ also downloaded the bin files for obd1. So i'm ready
Old Jan 11, 2004 | 04:45 PM
G U E C O's Avatar
can u jsut socket and add a chip to your 5 speed p28? is the capasitors and resistors nescessary?
HondaRipper1436
Engine Management and Tuning
10
Feb 8, 2011 08:33 PM
95sloweg
Jan 14, 2008 05:46 PM
memorybox
Nov 28, 2006 07:58 PM
tico
Oct 9, 2006 05:19 PM
Cyphear
Aug 5, 2004 06:11 AM
