Head Bolt Question
Old Jan 6, 2004 | 02:57 PM
NWHybrid's Avatar
Default Head Bolt Question
Can i reuse my headbolts...
Are there any bolts that i shouldnt reuse when going through a motor?
B18A1 80,000 going into my 88 Hatch DX
Old Jan 6, 2004 | 03:36 PM
kwik92hb's Avatar
Default Re: Head Bolt Question (NWHybrid)
no they are one time use only get some arp headstuds and u can use them over and over
Old Jan 6, 2004 | 05:06 PM
doublejz's Avatar
Default Re: Head Bolt Question (kwik92hb)
you can reuse them, but they do stretch and break. They are recommended to be replaced each time they are removed. I personally have used the same head bolts three times without any problems
Old Jan 6, 2004 | 05:17 PM
NWHybrid's Avatar
Default Re: Head Bolt Question (doublejz)
I just bought ARP stud kit for the B18A1 from summit...
How do i put them in?
Old Jan 6, 2004 | 08:34 PM
builthatch's Avatar
MiG-21 superfan
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NWHybrid &raquo;</TD></TR><TR><TD CLASS="quote">I just bought ARP stud kit for the B18A1 from summit...
How do i put them in?</TD></TR></TABLE>
uhh, screw them in to the block completely (make sure you lube them with mineral based oil or assembly lube) then torque. If you can not screw them in, dremel a slight notch in the top and screw them in w/ a screwdriver.
eddie7978
Engine Machining & Assembly
25
Feb 22, 2018 08:19 AM
JDM_DAKiD
May 20, 2015 01:43 PM
Mishako129
Sep 11, 2013 08:11 PM
Soccerking3000
Aug 13, 2004 03:43 PM
ELSpool
Jul 28, 2003 11:21 AM
