car is rattling after i tried to take the cat off
Old Jan 6, 2004 | 09:38 AM
Cyber ITR's Avatar
Default car is rattling after i tried to take the cat off
ok so one day i tried to take the cat off , but i didnt manage to take off the 3 bolts on the back of the cat.
So i put everything back like before, guess what the car is rattling everytime i take off and at some certain rpm.
any idea what causes the rattling noise ??
thanks
Old Jan 6, 2004 | 09:44 AM
Cyber ITR's Avatar
Default Re: car is rattling after i tried to take the cat off (Day Walker)
and if i vtec it , it makes some sort of buzzing noise , really really annoying
hope it has nothing to do with my engine ...
Old Jan 6, 2004 | 09:49 AM
DsITR's Avatar
check all heatshields for clearance..
did you get the springs that surrond the bolts on the cat fastened properly? sometimes backing those off a bit will help get rid of vibration.
just make sure you have no exhaust leaks afterwords.
Old Jan 6, 2004 | 09:50 AM
People_Mover's Avatar
From: HT PRO POKER PLAYER IM FOR FREE STARTUP, MONEY
probably rattling against the heat shield. Park your car and jack it up and pull on the piping back and forth and see if it rubs against anything or just remove the heat shield all together.
Old Jan 6, 2004 | 09:51 AM
Cyber ITR's Avatar
Default Re: car is rattling after i tried to take the cat off (RealTypeR)
i will try to do that after work
thanks guys
Old Jan 6, 2004 | 11:09 AM
DC2fanboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Day Walker &raquo;</TD></TR><TR><TD CLASS="quote">ok so one day i tried to take the cat off , but i didnt manage to take off the 3 bolts on the back of the cat.
thanks</TD></TR></TABLE>
Those bolts are annoying, and if you managed to get them off, getting them back on is even worse...
And like they said... it's the heatshield 9 times out of 10 that rattles...
Old Jan 6, 2004 | 11:55 AM
1GreyTeg's Avatar
Default Re: car is rattling after i tried to take the cat off (DC2fanboy)
Another Vote for heat shields here
I've had various heat shield issues on all 3 of my Gen 3 Integra's as well as on my old CRX. Honda heat shields just love to find a way to sneak in a good buzzing rattle.
Old Jan 6, 2004 | 12:20 PM
JjuuN R's Avatar
Default Re: car is rattling after i tried to take the cat off (1GreyTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1GreyTeg &raquo;</TD></TR><TR><TD CLASS="quote">Another Vote for heat shields here
I've had various heat shield issues on all 3 of my Gen 3 Integra's as well as on my old CRX. Honda heat shields just love to find a way to sneak in a good buzzing rattle.</TD></TR></TABLE>
i agree, also check those tension springs while you're down there too
Old Jan 6, 2004 | 05:51 PM
Cyber ITR's Avatar
Default Re: car is rattling after i tried to take the cat off (JUN.R)
one more thing
i was searching for some old posts , and one of the guys said it could also be a spun rod bearing , is that true ??
what does a spun rod bearing sounds like ???
does an engine with a spun rod bearing still drives normal ???
thanks guys
Old Jan 6, 2004 | 05:55 PM
Cyber ITR's Avatar
oh by the way the car drives fine , only when at WOT it makes buzzing noise , but still pulls like usual
Old Jan 6, 2004 | 08:33 PM
Cyber ITR's Avatar
Old Jan 6, 2004 | 08:42 PM
Yellow3TypeR's Avatar
another heat shield vote.....that was my prob when I had the same sound
Old Jan 6, 2004 | 08:47 PM
Kicker773's Avatar
Default Re: (Yellow3TypeR)
yup maybe its the heatshield..
Old Jan 6, 2004 | 08:49 PM
Cyber ITR's Avatar
the heat shield where are talking about here
its not the exhaust manifold heat shield , is it ??? but the heat shield on the top and bottom of the cat, right ???
thanks
Old Jan 7, 2004 | 12:25 AM
Boges's Avatar
Default Re: (Day Walker)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Day Walker &raquo;</TD></TR><TR><TD CLASS="quote">the heat shield where are talking about here
thanks </TD></TR></TABLE>Yup the one on top of the cat. The only downside to taking it off is its a little hotter around the shiftknob and e-brake. If you can handle that, then you might as well just take it off.
Old Jan 7, 2004 | 09:05 AM
Cyber ITR's Avatar
Default Re: (Boges)
ok i will try to do that later on if its not raining.
thanks guys
Old Jan 7, 2004 | 02:19 PM
Cyber ITR's Avatar
ok
i have took the headshields on the cat off
and its still rattling , **** its pissing me off
the sounds coming from the engine bay
Old Jan 8, 2004 | 03:16 AM
Cyber ITR's Avatar
up up
help a brother out please
im going to make a sound clip if i have time , jdm piece a ****
Old Jan 8, 2004 | 03:20 AM
Chris_R's Avatar
I had the heat shield problem on an old Galant I had, and I thought I was having the same problem but it turned out to be small cracks in the welds by the resonator. you might wasnt to look over all the welds in your exhaust. Good luck.
Old Jan 8, 2004 | 10:01 AM
Cyber ITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Day Walker &raquo;</TD></TR><TR><TD CLASS="quote">what does a spun rod bearing sounds like ???
thanks guys</TD></TR></TABLE>
JDMEK9R
Jan 9, 2008 10:58 AM
Voodooboy520
14
Aug 14, 2006 01:52 PM
lastpunkinline
Apr 7, 2005 07:48 AM
ridiculous
13
May 8, 2003 10:13 PM
StinkyTofu
Feb 16, 2003 12:27 AM
