CTR piston in ls motor?
Old Jan 5, 2004 | 08:02 PM
JdM_Ls_PwR425's Avatar
Default CTR piston in ls motor?
i was told ctr pistons in an ls block with a thin one-layer head gasket will make my compression ratio 12:0. Is that safe for me to run on a well built up ls motor?
Old Jan 5, 2004 | 09:49 PM
dfoxengr's Avatar
Default Re: CTR piston in ls motor? (JdM_DoHc_PoWeR425)
yes
Old Jan 5, 2004 | 10:13 PM
mmuller's Avatar
Mad Scientist
pct's on b18a/b block with stock headgasket compression is about 13.
Old Jan 5, 2004 | 10:14 PM
onesikviet's Avatar
Default Re: CTR piston in ls motor? (mmuller)
mill ur head too while ur at it
Old Jan 6, 2004 | 09:35 AM
BoOsTeD_eK's Avatar
Default Re: CTR piston in ls motor? (onesikviet)
Please do not forget to supply ample fuel to your setup...running high c-ratios on a standard fuel setup will lead to problems!
Old Jan 6, 2004 | 01:38 PM
onesikviet's Avatar
Default Re: CTR piston in ls motor? (BoOsTeD_eK)
whats a good fuel mod for high comp.?
Old Jan 6, 2004 | 02:05 PM
eyeamvic's Avatar
What cams do you plan on running in order to need that high of a compression? I hope they're some huge custom cams cuz all the ones out don't need anything higher than 11.0:1.
Old Jan 8, 2004 | 07:43 PM
JdM_Eg_6's Avatar
Default Re: (eyeamvic)
Bump!
Old Jan 9, 2004 | 10:49 AM
martini's Avatar
Default Re: (mini_me)
you're going to need to modify your rods to fit the pistons though.
you could probably get away with using an AFC and tuning it richer for fuel. if not, some bigger injectors may be in order.
Old Jan 9, 2004 | 02:00 PM
AllMotorMadness's Avatar
I did the same same setup a year ago it works fine, ctr pistons in an LS and I even had the head milled 25k. It ran on pump gas as well as stock cams did bother with buying a cam for an ls motor
Old Jan 9, 2004 | 05:34 PM
JdM_Eg_6's Avatar
Default Re: CTR piston in ls motor? (AllMotorMadness)
what pistons would everybody rather use for my set up
jdm ctr's or jdm itr's
set up:
B18b head-
with a wild port and polish job, crower stage 3 cams, crower springs and retainers, new valves, and a larger fuel pump with a 2 or 1 layer head gasket with 2 layer ill be pushing out about 11:7 compression and with the 1 layer ill be pushing 12. what does everybody think i should do to get max power (92 octane) should i mill my head at all since compression is already going to be high?
B18b block-
jdm ctr pistons .025 oversized, machined to my ls rods and balanced, and a machined crank
P.S. I will also be running a hondata stage 4 programed ecu
cisurfer1
Feb 20, 2006 08:31 PM
shreddinryguy
May 7, 2004 10:00 PM
Mr HYDE
Mar 22, 2004 07:20 PM
ID_ten_T
Jun 15, 2003 04:14 PM
chirp2hrd
May 29, 2002 07:17 AM
