SHIFTING
Old Jan 5, 2004 | 06:27 PM
joeyandhiscrx's Avatar
Default SHIFTING
hi..i have this problem...i have an 88 crx wth a b16 swap...the car wont go into any gear until i throw it into reverse adn then it is really easy...if i dotn throw it into reverse....its really hard and i have to force it into first.does any one know whats wrong?
Old Jan 5, 2004 | 06:40 PM
To Muckin Fuch's Avatar
Default Re: SHIFTING (joeyandhiscrx)
try checking your throw out bering or your synchros
Old Jan 5, 2004 | 08:35 PM
Default Re: SHIFTING (To Muckin Fuch)
do you think it has anything to do with the clutch cable.?
Old Jan 5, 2004 | 08:39 PM
Vero's Avatar
your synchros is way off.
Old Jan 6, 2004 | 05:09 AM
SIRX's Avatar
have you had the tranny apart for any reason? Alot of time people that have no experience taking tranny's apart try to install lsd's or gear-sets and when assembling the tranny the shift forks get messed up. I had to pull apart a tranny for a guy that had really similar problems to yours. After getting the tranny apart the forks were all messed up. it was an easy fix but I'd suggest taking it to a reputable tranny builder.
Old Jan 6, 2004 | 05:15 AM
Mr Furball's Avatar
With the clutch pushed in, try to put it into 3rd first and then into first. Third gear is what lines all the gears up. This might help.
Old Jan 6, 2004 | 05:23 AM
Home Skillet's Avatar
I had the same problem when I was using heavy weight tranny fluid. The problem went away when I replaced it with Honda MTF.
Old Jan 6, 2004 | 05:13 PM
Default Re: SHIFTING (FURBALL B-16)
yeah..instead of throwing it into third...i have to throw it into reverse first
Old Jan 6, 2004 | 06:09 PM
what kinda tranny fluid should i get if that is even the problem
Old Jan 6, 2004 | 06:34 PM
EG8R's Avatar
Honda MTF....
Old Jan 6, 2004 | 07:20 PM
speed_racer012's Avatar
Default Re: SHIFTING (skelly ed6)
I had the same problem on my d series. I dropped the tranny and put in a new throw out bearing and it works perfectly now
Old Jan 7, 2004 | 03:53 AM
Mr Furball's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed6 &raquo;</TD></TR><TR><TD CLASS="quote">Honda MTF....</TD></TR></TABLE>
01_em2
Transmission & Drivetrain
Sep 30, 2010 02:37 PM
phelpsj2
May 18, 2010 03:40 PM
GWInquisitor14
Oct 15, 2004 10:06 AM
pelotudo
15
Sep 7, 2002 08:27 PM
Fr0m4311
Apr 7, 2002 09:31 PM
