Main Relay Location?
It must be my main relay since I am getting fuel and I have replaced the dizzy. The car still will not start after it warms up. Please help me ASAP with location of the Main Relay and I am open to any suggestions. Thanks in advance.
From: I told you to wait in the truck in Texas, United States
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Z6REX-SI »</TD></TR><TR><TD CLASS="quote">Is this hard to replace?
Thanks</TD></TR></TABLE>
Nope not at all, hardest thing is getting at the bolt.
The way the guys at the Honda dealership do it is to take the insides
from the new relay and just pop them into the old case not bothering with unbolting it from the car...
When you get your new one,Look at the bottom where it snaps in..
It has two tabs which hold it in place..
Is it possible for the main relay to be messed up and the fuel pump still manage to come on?
I have a walboro external fuel pump and it is right under the hood. I replaced the dizzy so I figured it would have to be the Main Relay. My fuel pump does not sound the same on those occasions that my car does not start but it does come on. Does it still sound like the Main Relay??
Here is an good article on troubleshooting. (read all 3 pages)
http://autorepair.about.com/cs...a.htm
Another link on relay replacement:
http://honda.hybrids.jp/tech/p...shtml
When my relay went bad,The pump would not come on intermitantly...
This is a thread I did on my main relay:
https://honda-tech.com/zerothread?id=677135
My car would start then die when it got warm and wouldn't start again.
I thought for SURE it was fuel related. I replaced my gas cap, my fuel filter, my main relay AND my ignition switch.... turned out I wasn't getting spark and I had to replace my coil and ignitor (for the 3rd time!).
