can i pass smog in cali with a p28???
i have a 97 b18cr in a 95 civic, would i be able to pass smog with a stock p28??? would my motor run good at all??? or am i stuck with wiring up a ckf and going with a usdm p73?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR »</TD></TR><TR><TD CLASS="quote">I am testing my b16 del sol w/ a p28 tomorrow. I'll let you know how it goes. Do you have to go to a state ref? or just smog?</TD></TR></TABLE>
cool let me know! probably gonna test it at a smog station (scurd of the ref)
I passed at a test only center with a b16 w/p28 and ctr cams. It just barely passed because it was being tested as a 1.6 sohc as the chassis should have had...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EG2 SiR »</TD></TR><TR><TD CLASS="quote">I passed at a test only center with a b16 w/p28 and ctr cams. It just barely passed because it was being tested as a 1.6 sohc as the chassis should have had...</TD></TR></TABLE>
the state ref checks the ecu you are running....
also from what i gathered from my whole smog experience is that the numbers are not too far off possibily even similar..
I basically put 2 and 2 together and OBD I honda motors are basically the same...they are all pretty clean and im guessing are tested with the same or close to numbers...
i found this out because i wanted to get a pretest on my 95 jdm b18c....and at the pretest station they were having problems with the computer because you have to put in a certain number so that the computer will be able to read your emissions...
I asked them if they can just plug in a 95 integra gsr into there and pretest it as that...the smog tech said that they can smog it as my stock motor (d16z6) because the numbers were virtually the same....
and...
when i went to the ref....they smogged my car as a 95 gsr and the numbers were the same as my 93 d16z6.....
hope that helps...
and...
hope that helps...
Munkyw3rkz.webs.com
i have a barred B18C1 94 Hatch and i smogged it with the P28 because it was due.
at first she failed but i noticed he was running it as the D seies then told the guy no its a 1.8 not a 1.5
he was like you can do that why did you say that to me i cant smog your car
i showed him the bar sticker and he shut up quick.......passed no problems.....i even think i forgot to cut the jumper for the chip!!!!
didnt even tune the car
one slow eg5
12
Oct 9, 2004 07:35 PM
