problem with hondata! help
Old Jan 5, 2004 | 02:40 PM
vtekthis's Avatar
Default problem with hondata! help
i installed my hondata on my 99 civic ex with an 00 b16 swap. we put the chip into the p28 comp hooked up the hondata and all it does is blinck the light. i heard that if the light does not stay on solid then the hondata has not yet connected to the computer. What would cause this. tried other p28's, interface boxes, and even jumper harnesses. the hondata is a stage 2 with boost option
Old Jan 5, 2004 | 03:01 PM
vtekthis's Avatar
come on someone gots to know this
Old Jan 5, 2004 | 03:33 PM
vtekthis's Avatar
ttt
Old Jan 5, 2004 | 05:52 PM
bardo's Avatar
Default Re: problem with hondata! help (vtekthis)
darren why dont you call wunk?
Old Jan 5, 2004 | 11:14 PM
vtekthis's Avatar
still having problem! where are all the hondata gurus
Old Jan 6, 2004 | 04:58 AM
se93's Avatar
Here is a part from the S200 Installation manual, which you can download from hondata. Here is the link: http://www.hondata.com/downloads.html
The interface box LED is flashing slowly
The problem lies with the Hondata interface box not being able to communicate with the ECU. Possible causes for this problem:
• Incorrect ROM used for the ECU.
• ROM inserted the wrong way around.
Old Jan 6, 2004 | 06:42 AM
b18cx's Avatar
Default Re: problem with hondata! help (se93)
Or maybe there's no program on the chip????
Old Jan 6, 2004 | 07:01 AM
vtekthis's Avatar
does the rom lay dependent on the system? ie, stage 2 needs a stage two chip and cannot use a hondata chip?
Old Jan 6, 2004 | 08:40 AM
Spunkster's Avatar
Default Re: (vtekthis)
Who programmed the chip with a base map?
They do not ship from Hondata with a base map burned into them. THis is done by your dealer.
Old Jan 6, 2004 | 10:16 AM
b18cx's Avatar
Default Re: (Spunkster)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Spunkster &raquo;</TD></TR><TR><TD CLASS="quote">Who programmed the chip with a base map?
They do not ship from Hondata with a base map burned into them. THis is done by your dealer.</TD></TR></TABLE>
Old Jan 6, 2004 | 11:44 AM
vtekthis's Avatar
i had a tuner burn the chip, then we found this problem, burned another still did not work, we bashed minds trying to figure this out
Old Jan 6, 2004 | 11:46 AM
vtekthis's Avatar
are the chips the same from the s200 and the stage two, we burned the stage 2 base map but no luck
Old Jan 11, 2004 | 10:41 PM
Spunkster's Avatar
make sure tha jumper j12 has not been cut when used with a staged system
boostdvic
Aug 6, 2008 09:01 AM
shyboi4u
May 11, 2006 09:53 PM
-iLLuZioN-B18C1
Dec 28, 2004 01:06 PM
qwklude82
Mar 21, 2003 02:09 PM
