Does the wg spring rate is important if the boost is controled via AEM EMS ?
like the topic say ... If I want to boost something like 20 psi and the spring is a 5 psi spring does it influence something like faster spool or anything like this ??? I got a TIAL 38 MM ...
I had a Greedy turbo kit controled by my AEM EMS before and I didnt change the spring so I belive that with an external wg this is the same thing ???
Thanx for the info even if it seem stupid I dont know ???
I believe the rule of thumb is don't boost past twice what your spring is rated. Probably because of spiking/reliability issues.
-PHiZ
-PHiZ
Some EBC's, like the Profec B, can't go more than double the wastegate spring for some reason. It's a huge pain in the ***, that's for sure.
I'm not sure if AEM is the same, probably not.
I would run a spring a few psi less then the lowest boost you want to run, no reason to use a 5 psi spring really.
normally we like to run on the wastegate spring for low boost. it makes things easier. but if you want to use the boost control to raise it then a 10-12 psi spring would work well for 15psi boost.
9deuce9rr
Mar 28, 2004 12:32 PM
Short Round
Nov 12, 2003 10:16 PM
