Head unit and cds burning up... volume fluctuating??!?!
Old Jan 5, 2004 | 10:14 AM
Money $hot's Avatar
Default Head unit and cds burning up... volume fluctuating??!?!
i have a kenwood head unit... cant remember the exact model, one of the medium-end models. anyway, i dont have an amp in my 96 ex coupe, and i usually play my stereo at volume level 25 which is fairly loud, but not really that intense. anyway, i notice that my head unit and cds get REALLY hot, and the volume, while staying at 25, goes way down in loudness for like 5 minutes, then will go back up, then goes back down. it does this even when i havent been listening to the stereo for very long... any ideas? maybe bad wiring? i had the alarm dudes wire it up for me when they did the alarm.
Old Jan 5, 2004 | 10:37 AM
made you look
Guest
Posts: n/a
if its a burned cd, some songs are louder then others. cd will always get hot when you leave them in the deck for a certain amount of time. i think the friction from the spinning heats it up.
Old Jan 5, 2004 | 10:46 AM
Money $hot's Avatar
Default Re: (made you look)
well its not that some songs are louder.. the volume actually changes during songs... burned or not. any other ideas?
Old Jan 5, 2004 | 12:50 PM
djurbang's Avatar
Default Re: (tovlakas)
bad wiring is what it sounds like, i know there's an squeel you can get from bad wiring too, but i can't remember what this one is from, hopefully one of the other guys on H-T can help...bump
Old Jan 5, 2004 | 03:50 PM
Money $hot's Avatar
Default Re: (djurbang)
should i just take it back to the place and demand that they rewire it?
i would do that i just wanted to make sure it wasnt just cuz i didnt have an amp in the car... cuz i am putting one in for the regular speakers pretty soon its 200 watts.
Old Jan 5, 2004 | 07:37 PM
brads94accord's Avatar
Default Re: Head unit and cds burning up... volume fluctuating??!?! (Kissmya##)
mine does the same thing after listening to it at about 25 for a while, i believe it turns the volume down so it doesn't overheat
Old Jan 5, 2004 | 10:17 PM
tumbleweed's Avatar
Default Re: Head unit and cds burning up... volume fluctuating??!?! (tovlakas)
It sounds like it is most likely a bad ground for the Cd player or it is a bad cd. player Have someone or yourslef that knows electrical wiring to check the ohm reading on the ground wire. it shouldn't be more then .10-.15ohm's max if it is more it will cause the radio to do exactly what is happening to you. if the ground ohm reading is ok then you most likely got a bad radio.
Old Jan 8, 2004 | 07:21 PM
djurbang's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tovlakas &raquo;</TD></TR><TR><TD CLASS="quote">should i just take it back to the place and demand that they rewire it?
i would do that i just wanted to make sure it wasnt just cuz i didnt have an amp in the car... cuz i am putting one in for the regular speakers pretty soon its 200 watts.</TD></TR></TABLE>
that's the glory of having other professionals do your installations, if they eff up then they have to fix it themselves!!
the watt shortage shouldn't have anything to do with the head unit heat or volume fluctuating. the only thing that would happen there is speaker clipping and bad sound.
Old Jan 9, 2004 | 01:00 PM
[626]phixionEF91's Avatar
your prblem is this. you have a kenwood
i had been told not to buy a kenwood by many of my audio buddies cuz they have had problems with their preamps over heating. the problems they had were i denticle to yours, but i went and bought one anyways
same ish happend to me.
i replaced it with a blaupunkt austin cd41, big difference
Old Jan 10, 2004 | 09:13 AM
foz's Avatar
foz
the problem is not in the wiring....
instead of shutting down from overheating the headunit is going into a from
thermal protection where it limits the output so that the internal amplifier has
a chance to cool off. if you add an amplifier to your door speakers it will take
most of the work away from the head unit and although expensive it would fix the problem.....
bgioan
Audio / Security / Video
13
Aug 23, 2011 10:42 PM
I Love My Ejay8
Aug 18, 2005 11:51 AM
dylokjai
Mar 22, 2005 02:01 PM
nightryder21
Jan 28, 2004 06:21 PM
DC2_Integra
Jun 7, 2002 02:06 AM
