Difference between stock ITR shifter and LS shifter?
Old Jan 4, 2004 | 06:02 AM
JDubya's Avatar
Default Difference between stock ITR shifter and LS shifter?
Some say there is, some say there isn't, so which is it? And is it true that short shifters are bad for you tranny?
Old Jan 4, 2004 | 09:05 AM
MK Ultra's Avatar
Default Re: Difference between stock ITR shifter and LS shifter? (ALL MOTOR LS)
Only difference is the ****.
Short shifters aren't necessarily bad for the tranny. Poor shifting technique is. By making the shifts even shorter than stock you increase the chance of you screwing up the transmission if you're not careful.
Personally, I find I can shift faster than the transmission can handle with the stock shifter, so I see no need whatsoever to shorten the shifts even more.
SoyMilk
55
Mar 27, 2010 10:11 AM
uses0ap
Jan 24, 2009 07:48 PM
teg92
Aug 26, 2003 10:30 PM
champITR
Sep 3, 2002 05:32 PM
2k1_ITR_0736
31
Jul 20, 2002 08:41 AM
