which fpr?
Old Jan 3, 2004 | 11:59 PM
redboost10's Avatar
Default which fpr?
i searched but didnt find anything under fpr or fuel pressure regulator. for my fuel i have a walboro 255 and getting rc 550cc's and hondata. i was wondering what fpr to run? would a aem be fine? thanks for the help.
Old Jan 4, 2004 | 12:27 AM
mamaboy's Avatar
Default Re: which fpr? (tgh99si)
sx, paxton, aeromotive
Old Jan 4, 2004 | 12:28 AM
Kwuaymaikrup's Avatar
Stock will work just as good. Unless you are upgrading to a larger return line and need an AN fitting I would just keep the stock one.
-Ryan
Old Jan 4, 2004 | 12:38 AM
redboost10's Avatar
Default Re: which fpr? (Kwuaymaikrup)
will stock really work with the pump and the 550 injectors? how can you raise the fuel pressure with the stock one?
Old Jan 4, 2004 | 12:51 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tgh99si &raquo;</TD></TR><TR><TD CLASS="quote">will stock really work with the pump and the 550 injectors? how can you raise the fuel pressure with the stock one?</TD></TR></TABLE>
I am under the impression that with Hondata there isn't really a need for one. I could be and am probrably wrong though.
-Ryan
Old Jan 4, 2004 | 09:40 AM
redboost10's Avatar
anyone else? what fpr are you guys using?
Old Jan 4, 2004 | 09:43 AM
TurboJesse
Guest
Posts: n/a
stock yO!....it works fine with hondata,fuel pump, injectors...
Old Jan 4, 2004 | 09:58 AM
PH_B16-VTi's Avatar
Default Re: which fpr? (Mpir3)
When using Hondata, you keep the base presure and get bigger injectors and adjust the fule map in the hondata.
/PH
Old Jan 4, 2004 | 10:06 AM
redboost10's Avatar
Default Re: which fpr? (PH_B16-VTi)
alright finally a place to save money on something. thanks guys.
Old Jan 4, 2004 | 11:00 AM
Yay! I do know something!
Old Jan 4, 2004 | 02:22 PM
Silverbeast's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by PH_B16-VTi &raquo;</TD></TR><TR><TD CLASS="quote">When using Hondata, you keep the base presure and get bigger injectors and adjust the fule map in the hondata.
/PH</TD></TR></TABLE>
Not exactly true, you get the benefit of actually running a lower fuel pressure with the Hondata and not having the injectors at 100% duty cycle so quickly as with stock fuel pressure settings.
I reccomend (and so does hondata) getting a true 1:1 rising rate fpr.
I run the Aeromotive...
BTW, the stock regulator isnt 1:1 as many other tuners on this board can telll you.
Old Jan 4, 2004 | 05:04 PM
AVATAR's Avatar
Default Re: which fpr? (HoustonSi)
Aeromotive.
Old Jan 4, 2004 | 05:15 PM
Bulldogg83's Avatar
Default Re: which fpr? (AVATAR)
stock
Old Jan 4, 2004 | 06:54 PM
redboost10's Avatar
Default Re: which fpr? (Bulldogg83)
any more opinions on running stock or aeromotive? where can i buy the aeromotive that bolts directly to the stock location? i cant find it
Old Jan 4, 2004 | 07:09 PM
You are going to need a fitting to come off the fuel rail to the aeromotive.
Old Jan 4, 2004 | 07:16 PM
redboost10's Avatar
i thought they make a aeromotive that bolts right to the stock location. ok do you know where i can buy a aeromotive other than aeromotive.com
Old Jan 4, 2004 | 07:18 PM
I believe i got mine from http://www.Jegs.com
I know it comes with some hardware, but it's been over a year since i bought mine.
Old Jan 4, 2004 | 07:21 PM
redboost10's Avatar
thanks man
Old Jan 4, 2004 | 08:21 PM
baphomet's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoustonSi &raquo;</TD></TR><TR><TD CLASS="quote">
BTW, the stock regulator isnt 1:1 as many other tuners on this board can telll you. </TD></TR></TABLE>
Oh really? So you apply one pound of pressure to the spring and some how that isn't one pound? You apply two pounds and that isn't two pounds? ETC...
Please enlighten me.
I run B&M only to play with fuel pressure to fine tune my direct port setup else I would keep it stock.
Old Jan 4, 2004 | 08:59 PM
It's been covered and debated...
https://honda-tech.com/zerothread?id=93758
I noticed the same thing on my 00 Si.
Old Jan 5, 2004 | 12:24 PM
baphomet's Avatar
Default Re: (HoustonSi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HoustonSi &raquo;</TD></TR><TR><TD CLASS="quote">It's been covered and debated...
I noticed the same thing on my 00 Si.</TD></TR></TABLE>
Thanks for the link
Old Jan 5, 2004 | 12:35 PM
baphomet's Avatar
Default Re: (slashDEVslashNULL)
I am curious how my B&M will behave under boost.
bcintron95
Jun 13, 2018 02:47 AM
Freemananana
Feb 22, 2014 03:40 PM
g0tgot
Nov 2, 2008 10:27 AM
RyanAutry
Mar 23, 2003 09:47 PM
redline201
Feb 6, 2003 08:02 PM
