How much can I safely bore out my B16 to?
Old Jan 3, 2004 | 05:33 PM
boredracer408's Avatar
Default How much can I safely bore out my B16 to?
Im building a B16 block for mild turbo use and wanted to bore out the stock sleeves. Is 81.25mm good or can I go a little more? I wanted to do this safely without sleeving it. Im gonna also put in a block guard.
Old Jan 3, 2004 | 05:39 PM
BoostedSi's Avatar
Default Re: How much can I safely bore out my B16 to? (boredracer408)
I've heard you shouldnt go past 82mm. 81.25 or 81.5mm will work fine
Old Jan 3, 2004 | 05:57 PM
InTeGrA B18b1's Avatar
Default Re: How much can I safely bore out my B16 to? (BoostedSi)
i was reading a post on this guy that bored his 1.6 to 83mm. i think thast like 1.9 almost 2.0?
Old Jan 3, 2004 | 06:04 PM
baphomet's Avatar
Default Re: How much can I safely bore out my B16 to? (InTeGrA B18b1)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by InTeGrA B18b1 &raquo;</TD></TR><TR><TD CLASS="quote">i was reading a post on this guy that bored his 1.6 to 83mm. i think thast like 1.9 almost 2.0?</TD></TR></TABLE>
AFAIK it is barely 1.7.
Anyway, I think you should leave your STOCK sleeves alone. If you sleeve it then bore it out to 84mm, some people even go 84.5mm but I like to start at 83mm.
Old Jan 3, 2004 | 07:25 PM
Bulldogg83's Avatar
Default Re: How much can I safely bore out my B16 to? (slashDEVslashNULL)
I am getting my b16 block sleeved by Benson (earl) and we are going to bore it out to 83mm
Old Jan 3, 2004 | 08:22 PM
Unsung's Avatar
Default Re: How much can I safely bore out my B16 to? (Bulldogg83)
I'll be doing 82.5mm.
Old Jan 3, 2004 | 08:27 PM
havalilsi's Avatar
Default Re: How much can I safely bore out my B16 to? (Unsung EM1)
84 to 84.5mm sleeved will yield about 1.7L.
Old Jan 4, 2004 | 01:57 PM
so anything under 82mm is fine?
Old Jan 4, 2004 | 02:01 PM
alpha's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boredracer408 &raquo;</TD></TR><TR><TD CLASS="quote">I wanted to do this safely without sleeving it.</TD></TR></TABLE>
Old Jan 4, 2004 | 02:25 PM
h1coupe's Avatar
82mm will yeld 1634cc i think!
i am going to bore to either 81.5 or 82mm haven´t decided yet
Silverbeast's Avatar
81.5mm is fine with a blockguard, just make sure the machine shop installs and and makes sure everything is all straight with the blockguard on.
Old Jan 4, 2004 | 03:20 PM
queez's Avatar
Default Re: (HoustonSi)
i just got mine bored out to 84mm
Bulldogg83's Avatar
Default Re: (queez)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by queez &raquo;</TD></TR><TR><TD CLASS="quote">i just got mine bored out to 84mm</TD></TR></TABLE>
with or without sleeving it?
Old Jan 5, 2004 | 05:29 PM
queez's Avatar
Default Re: (Bulldogg83)
darton MID sleeves.
Old Jan 5, 2004 | 05:30 PM
Bulldogg83's Avatar
Default Re: (queez)
gotcha
b16a4
Feb 5, 2007 12:43 AM
B18 CYA
May 13, 2004 11:20 AM
onesikviet
Jan 4, 2004 07:38 PM
NOSED_CRX_VTEC
Sep 14, 2003 07:40 PM
SpdFrk
Aug 29, 2003 07:42 AM
