Is it hard to change a head gasket on d16a6? also see if you think its my head gasket?
I have never worked on a honda before, only old scholl volkswagen's so i was wondering if it is hard to do? i know it requires removing more than a few things but i am pretty mechanically inclined, but i just have always worked on aircooled vw's. So would it be a good idea to get a d16y8 head gasket for a 96 civic ex? it will give me a little more CP right? Anyways if anyone can give me some info that would be great, thanks guys. Oh by the way the reason i think i should replace is my car started overheating and the heater wouldnt blow hot air, and my car was blowing out some nasty bluish white smoke when i get on it, and a bad odor. So im pretty sure that is what it is, let me know if you have had experience with this, thanks.
sounds like a head gasket.
replacement is pretty straight forward, unplug everything from the intake manifold (if you choose to remove it, the gasket can be changed while leaving the intake manifold in the car and just unbolting it from the head. then disconnect the exhaust manifold, radiator hoses, sensors, etc. and remove the head.
put everything back the way you took it off and make sure you torque the head back down correctly, its two step.
for the d16a6, 22ft/lb and 49ft/lb
also look in your manual for the correct torque order of the bolts.
black-vtec
Nov 30, 2008 01:53 PM
hb_guy
Oct 14, 2005 11:52 PM
