a wastegate
Old Dec 31, 2003 | 03:11 PM
acc97lxAndy's Avatar
Default a wastegate
Hey guys is it possible to install a wastegate to the cold air intake without the turbo just to get the nice sound that it produces.
Old Dec 31, 2003 | 03:23 PM
ramoneguru's Avatar
Default Re: a wastegate (acc97lxAndy)
Ok lets get the purpose of a wastegate down first --> wastegate releases built up pressure that is unusable by the turbo hence the chripping noise from the gate opening...now to install it into a cold air intake I don't even know how that's possible....Just have a friend sit in the passenger side and go "psssh....pshhh....pssssh" when you shift same effect
But what happens when people ask you to pop the hood to check out the turbo....what u gonna say?? "I like to pretend that I have a turbo".....
Old Dec 31, 2003 | 03:35 PM
97F22B2's Avatar
Default Re: a wastegate (ramoneguru)
actually a wastegate controls boost by bleeeding off exhaust gases via vacuum, your thinking blow off valve.
For a blow off valve to work you need positive intake pressure which no N/A car can do with out being forced, hence why turbos and supercgargers are called forced induction. Blow off valves only bleed off air so the conpressor fan of the turbo isnt foced to "surge" and rub against the housing.
someone needs to be doing a lot of reading, noobs.
Old Dec 31, 2003 | 05:30 PM
iam7head's Avatar
Default Re: a wastegate (97F22B2)
hahahahahahahhahahahhahahahahahaahahaha
this is sig. material..hahahahaha
wastegate doesnt makes that cool pssst psssssh sounds, it's the blow off valve you talking about.
mang, this is too funny
Old Dec 31, 2003 | 06:03 PM
so that means that the blow off valve makes that pssst noice because of the the air that it is being forced by the supercharger.!
Old Dec 31, 2003 | 06:06 PM
iam7head's Avatar
Default Re: (acc97lxAndy)
THe blow off valve relieve the pressure in the charge pipe, during a shift or stop.
without the bov, the throttle plate is gonna be damaged by all the pressured air built up by the compressor
and no, you heard the cool bov when it when the bov is open
Old Dec 31, 2003 | 07:10 PM
fluidaccord1's Avatar
Default Re: (iam7head)
special
Old Dec 31, 2003 | 07:47 PM
Crono139's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ramoneguru &raquo;</TD></TR><TR><TD CLASS="quote">But what happens when people ask you to pop the hood to check out the turbo....what u gonna say?? "I like to pretend that I have a turbo".....</TD></TR></TABLE>
Bahahahahaha. This is classic.
Old Dec 31, 2003 | 08:35 PM
Starrman85's Avatar
Default Re: a wastegate (Crono139)
if you want the BOV sound, buy one of those things you hook up to a speaker and your tach, and it will make that noise..............ricer.
Old Dec 31, 2003 | 09:46 PM
Crono139's Avatar
Default Re: a wastegate (STARRMAN85)
There's also those attachments that go on your exhaust canister.
Old Jan 1, 2004 | 07:44 PM
accordfreak's Avatar
easy free mod.. stick your head out the window each time you shift and go pshhhhhhhhhh
Old Jan 1, 2004 | 11:47 PM
ramoneguru's Avatar
Default Re: a wastegate (accordfreak)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by accordfreak &raquo;</TD></TR><TR><TD CLASS="quote">easy free mod.. stick your head out the window each time you shift and go pshhhhhhhhhh</TD></TR></TABLE>
Yeah he was talking bout a wastegate so it'd be more of a "chirp" sound (I was thinkin the pshhhhhhht thing too probably cause I was thinkin BOV also so don't feel left out )
Old Jan 2, 2004 | 06:41 AM
DrunkNRacer's Avatar
why are you guys even humoring this jackass
Old Jan 2, 2004 | 07:02 AM
1994AccordSiR's Avatar
Default Re: a wastegate (DrunkNRacer)
good question, just flame him like in the kills forum
4dek
May 27, 2008 10:55 PM
99Sivic
Oct 21, 2004 10:48 PM
x2gold
Apr 26, 2003 05:47 PM
Downey
Aug 7, 2002 04:12 PM
