anyone have timeslips for their jrsc sohc's?
Old Dec 31, 2003 | 11:21 AM
h45454's Avatar
Default anyone have timeslips for their jrsc sohc's?
Like it says above, does anyone have timeslips for their jrsc'd crx/ef's? I'm debating doing this, or building an na beast. I want at least low 15's out of it (here at 5800 ft above sea level - bandimere). Please share your thoughts. Thanks a lot.
Old Dec 31, 2003 | 12:04 PM
91civicDXdude's Avatar
i dont have a slip, but a guy i know ran a 13.5 with a y7/z6 minime and a jrsc@8psi
Old Dec 31, 2003 | 12:10 PM
crxgator's Avatar
Default Re: anyone have timeslips for their jrsc sohc's? (h45454)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by h45454 &raquo;</TD></TR><TR><TD CLASS="quote">Like it says above, does anyone have timeslips for their jrsc'd crx/ef's? I'm debating doing this, or building an na beast. I want at least low 15's out of it (here at 5800 ft above sea level - bandimere). Please share your thoughts. Thanks a lot.</TD></TR></TABLE>
im kinda deciding that too right now...good luck with whatever you decide your going with...
Old Dec 31, 2003 | 05:35 PM
h45454's Avatar
Default Re: (91civicDXdude)
Is that the same guy on d-series.org?
Old Jan 3, 2004 | 09:53 AM
exciv2000's Avatar
Default Re: (h45454)
My best so far was a 15.3 on a D16Y8 with 8 PSI, 25 shot of nitrous, 30 PSI in drag radials, full interor minus spare at 5800 ft ASL (Morrison, Colorado) spinning all the way through first. Next season will be a 35 shot, less PSI in drag radials, hoping for around 14.5
Old Jan 3, 2004 | 10:05 AM
crxgator's Avatar
Default Re: (exciv2000)
what was your base run? cause that seems really slow for all those mods...but then again you are high up in the air...
Old Jan 3, 2004 | 10:14 AM
exciv2000's Avatar
Default Re: (crxgator)
base at 6 PSI I think the best I mustered was a 16.8, not quite sure anymore. I think with just I/H/E I was hitting consistent low 18s, maybe a high 17 once. It's been a while.
Old Jan 3, 2004 | 01:04 PM
Timmah!!'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by exciv2000 &raquo;</TD></TR><TR><TD CLASS="quote">base at 6 PSI I think the best I mustered was a 16.8, not quite sure anymore. I think with just I/H/E I was hitting consistent low 18s, maybe a high 17 once. It's been a while.</TD></TR></TABLE>
And what what you mile an hour on thoes runs?
Old Jan 3, 2004 | 04:06 PM
SCD16A6's Avatar
my times in my sig,other mods:s-afc,msd btm, 3'' full exhaust,22''slicks,kamikazi header,hondata im gasket,act clutch and 11lb flywheel,the local track here is 4550ft so id say its possible to run low 15s were you are,but after all my experience with this setup i would go turbo.....trying to go 15s at 5800ft with a sohc allmotor setup would be pushing the everyday drivability of the car.
Old Jan 3, 2004 | 06:22 PM
greatgraffini's Avatar
holy **** that seems slow. Thats wierd, do you know how to drive? lol
Old Jan 3, 2004 | 11:14 PM
h45454's Avatar
Default Re: (SCD16A6)
Yeah, this altitude thing sucks. I can't swing the JRSC anymore, but I have an Exospeed race a6 cam I scored a deal on coming soon. I hope to hit the 15's all motor sohc non-vtec soon at 5800 ft above sea level. It shouldn't be too hard. My buddy's gutted std hatch (when it was still streetable) with stock dohc zc hit a 15.7 on street tires up here (I believe at Bandimere). His best is a 13.9 at PMI - same motor, open header, ~1600lbs with him in it. That's like a 12.9 at sea level.
95jeremie
Mar 6, 2007 03:15 PM
hybrid_KJ
Aug 22, 2005 04:42 PM
all_engine
Sep 3, 2003 10:52 PM
keebler65
Jun 9, 2003 09:10 PM
gitwidit
Jun 3, 2003 07:08 AM
