D15 Torque Specs, Guys I need someone with a Helms for bottom end specs
Old Dec 29, 2003 | 06:56 PM
Adi Radoncic's Avatar
On Fire!
Default D15 Torque Specs, Guys I need someone with a Helms for bottom end specs
Guys,
I need someone to do me a fawor and give me the torque specs to a d15 bottom end.
These are the specs I need:
Rod Bolts(nuts)
Crankshaft main caps with girdle Bolts
Oil Pickup
Baffle plate
Oil pump Bolts
Oil pan Bolts
Main Seal cover Bolts
Guys I need this desperately.. please help me!!!
Thanks,
Adi
Old Dec 29, 2003 | 08:56 PM
phatrick2332's Avatar
Default Re: D15 Torque Specs, Guys I need someone with a Helms for bottom end specs (newgsr)
rod bolts- 23 ft-lbs
main caps
seperate caps-48 ft lbs
one piece cap assembly- 33 ft-lbs
oil pickup tube - 17 ft-lbs
oil pump screen bolts- 8 ft-lbs
oil pump to engine bolts- 9 ft lbs
oil pan bolts- 9 ft lbs
main seal cover bolts? i have no clue lol
hope this help you out
pat
Old Dec 29, 2003 | 10:21 PM
EG8R's Avatar
Default Re: D15 Torque Specs, Guys I need someone with a Helms for bottom end specs (phatrick2332)
rear mail seal cover - 8 ft lbs
Old Dec 30, 2003 | 12:03 PM
On Fire!
Guys, thank you so much for this, I really needed these to finish my bottom end rebuild...
Thanks again!!
Adi
Old Dec 30, 2003 | 12:06 PM
EG8R's Avatar
Good luck!!!
Old Dec 30, 2003 | 03:34 PM
On Fire!
i need to know one more thing guys if you could please, look in the book and tell me if the bearing place ment on the one peace cap assembly matters, because right now I'm looking at it and there is ridges on both sides of the cap, does it matter where i put the bearing?? I mean does it matter on which side i put the bearing in on?
Thanks again,
Adi
Old Dec 30, 2003 | 05:57 PM
Im holding the book, and it doesnt say anything, the bearings are uniform and perfectly flat and round...it shouldnt matter.
Old Dec 31, 2003 | 01:07 AM
On Fire!
Default Re: (phatrick2332)
hey, i was gona post back but i got it now all it took is just looking at it.
I made an assumption way to early in the game, i didn't even look at that main cap gurdle..
Thanks for everything man...
Adi
lolv8s
Dec 1, 2016 10:05 AM
GSR_hatch936
Jul 6, 2008 08:00 AM
eortizr
Aug 23, 2005 10:08 PM
therealPROJEKTEG
Jun 7, 2005 05:10 AM
v930
Feb 16, 2005 08:22 PM
