Wiring up a b16 for ek. Could use some basic help.
Old Dec 29, 2003 | 04:49 PM
fcuked's Avatar
Default Wiring up a b16 for ek. Could use some basic help.
I've tried the Hybrid forum, and i've read through the links, but here goes my problem.
The motor is a '00 b16, and the car is a '96 civic.
I pulled out both harnesses and i compared them, then all the plugs that i was missing on the cx harness compared to the si one, i took them all out with the wires connected to the plugs. So basically i completely opened up the si harness and took the plugs out nice and clean. So now i have about 8 new plugs that i have to add, i don't know what half of them are for, i found the vtec pressure, and a few others. Now i am not sure if i have to run all plugs to my cx harness or just some. i was looking at the helms manual for a 96-98 ex wiring harness and some of the wires i have don't match p with any of the ones in the helms. So can somebody list exactly all the wires/plugs i need? Thanks.
Old Dec 29, 2003 | 05:19 PM
ghettochild's Avatar
Default Re: Wiring up a b16 for ek. Could use some basic help. (1.8 HB)
all you needed to use was your stock harness and swap the crank angle sensor plug and just run your vtec wires straight to your ecu plugs
Old Dec 29, 2003 | 05:29 PM
fcuked's Avatar
Default Re: Wiring up a b16 for ek. Could use some basic help. (ghettochild)
But there are a bunch of other bullshit wires, like one goes into the intake mani, the other , i think it's a temp sensor for the intake goes into the intake, then i have some other ones.
And how many vtec wires are there, vtec pressure, then what else is there, and also what colour is the knock sensor?
Which wires do i have to extend?
Old Dec 29, 2003 | 06:44 PM
DX187VTEC's Avatar
http://www.phear7imports.net/subs/btroop/trey/6gen/
slo_hatch
Oct 20, 2009 04:00 PM
Memnoch
Dec 12, 2007 08:05 PM
ridexstraight
Nov 25, 2004 08:22 AM
Nid Styles
Feb 25, 2004 09:50 AM
GripFactoR
Nov 21, 2003 02:36 PM
