Civic 95 COupe Ignition problems
Old Dec 29, 2003 | 11:09 AM
jobm's Avatar
Default Civic 95 COupe Ignition problems
Everything started with a crack in the distributor cap. After three weeks having the car halted, I changed the cap and try to start it and engine rotates but do not start. It had fuel in the piston and spark at the distributor (MSD clear cap) but the engine never started.
After 4 weeks of testing there is no spark at the distributor and Im thinking that the initial problem got bigger damaging the ECU. There are no error codes from the ECU all lights lite ok but nothing happens.
Any idea
regards
job
Old Dec 29, 2003 | 05:34 PM
NVturbo's Avatar
O.G. triple O.G.
Default Re: Civic 95 COupe Ignition problems (jobm)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jobm &raquo;</TD></TR><TR><TD CLASS="quote">Everything started with a crack in the distributor cap. After three weeks having the car halted, I changed the cap and try to start it and engine rotates but do not start. It had fuel in the piston and spark at the distributor (MSD clear cap) but the engine never started.
Any idea
regards
job</TD></TR></TABLE>
check your ignition coil....they go bad more often than you think...especially if you have an ignition amplifier installed. Try upgrading the internal coil for a external unit such as a "SS Blaster". This will definitely give your engine more spark!
Old Oct 7, 2004 | 09:03 PM
jdmda9's Avatar
im having the same problems with my 94 hb. c i bought the car as is and it was not runing, i starter form the simplest of things . checked all the fuses ,battery cables ,starter and distributer. there is power runing threw but noi crank.
Old Oct 7, 2004 | 09:37 PM
hatchi's Avatar
if its cranking and no spark. i'd check igniter and main relay and all fuses
honvic
Dec 4, 2011 07:27 AM
1badcrx
May 9, 2009 12:58 AM
eskimo10
Aug 23, 2007 01:25 PM
SI_niki
Jun 15, 2004 07:54 AM
dlric
Dec 13, 2001 03:55 AM
