Dremel uses??
Old Dec 29, 2003 | 08:48 AM
youngvedder's Avatar
Default Dremel uses??
Hey guys,
I recently got a dremel and thought it would be useful to polish up, port out (if possible) intake/exhaust plumbing. Anyone attempted this with a dremel? If so, and guidance that can be given?
Cheers,
Yv
Old Dec 29, 2003 | 08:54 AM
IN VTEC's Avatar
Default Re: Dremel uses?? (youngvedder)
I use a dremel for just about everything (porting manifolds, gaskets, cutting aluminum piping, drilling in tight spots). I'd use the air tank and compressor for porting manifolds, but it doesn't hold htat much air and it's a lot noisier than the dremel. It depends on how much material I have to remove. If there's a lot, then I start with the die grinder and carbide burrs.
Old Dec 29, 2003 | 09:09 AM
P1mpSlap's Avatar
man before I fried the motor in mine, I used that thing for everything.
Now I have to port **** by hand. **** that. Everyone that works on cars should have one. It's almost as important like the HELMs. lol
Old Dec 29, 2003 | 09:44 AM
StyleTEG's Avatar
Default Re: (P1mpSlap)
Keep in mind intake ports are supposed to be rough.
I personally wouldn't port/polish anything I couldn't easily test (to see if it helped or not) or replace.
Opening up the exhaust manifold a mm or two, can be benificial in preventing exhaust reversion.
Old Dec 29, 2003 | 02:14 PM
Default Re: (StyleTEG)
thanks guys......anyone else with tips?
YV
Old Dec 29, 2003 | 02:53 PM
naturelovindc2's Avatar
Default Re: (youngvedder)
Intake ports are usually supposed to be rough on carbed cars, assisting with the mixing of fuel and air. I've heard it's slightly beneficial to smooth the inside of fuel injected intake manifolds.
Old Dec 29, 2003 | 07:25 PM
StyleTEG's Avatar
Default Re: (naturelovindc2)
Its the same reason on fuel injected cars as well. Very smooth intake ports on the head will cause the fuel to pool.
Of cource you can go too rough as well, which is why I would leave it to professionals.
Old Dec 29, 2003 | 09:11 PM
That's why I'm going to make the runners on my intake manifold as smooth as possible. The head has already been done by a proffesional. The exhaust ports are real smooth, but the intake side has a little more texture to it.
Old Dec 29, 2003 | 09:52 PM
wodstlk's Avatar
I p&p'd my head with a dremel. took a long time but it made a noticeable difference. just be careful and not remove too much and cut into the coolant galilees...
Old Dec 29, 2003 | 09:55 PM
XtremeCarTuner's Avatar
Default Re: (wodstlk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wodstlk &raquo;</TD></TR><TR><TD CLASS="quote">I p&p'd my head with a dremel. took a long time but it made a noticeable difference. just be careful and not remove too much and cut into the coolant galilees...</TD></TR></TABLE>
gawd... i'll never trust myself to port my head.. But i have already used my dremel on the intake manifold. I went alittle crazy with it, but eh.. its just a manifold..
Old Dec 30, 2003 | 11:43 AM
Default Re: (XtremeCarTuner)
what bit do you guys use to smooth out the aluminum? I have tried a couple but they only last a minute or so, I must have the wrong bit.
any suggestions.
YV
Old Dec 31, 2003 | 03:11 PM
I've heard that while using a bit for final smoothing, it helps to use a lubricant such as WD-40. Supposed to prevent material from caking up in the bit and make it last longer.
Old Jan 4, 2004 | 01:17 PM
hey guys,
check out the 511 abrasive brush if your looking for a nice aluminum polishing bit. it works great!
YV
JDMCRX
Feb 5, 2009 05:16 PM
faultofhumanity
13
Sep 10, 2003 06:52 AM
teal_dx
Sep 25, 2002 10:08 PM
bluedelsol
Sep 8, 2002 03:59 PM
dragonhvu
Aug 15, 2002 01:57 PM
