what tool to use for polishing intake?
Old Sep 25, 2002 | 07:27 PM
teal_dx's Avatar
Default what tool to use for polishing intake?
I want to polish the inside of the runners on a 96 ex intake I will be swapping on my car w/ a mini-me swap. I wet sanded the first couple inches of the inside of the runners where the manifold bolts to the head, much smoother! so what can I do to smooth the parts I cant reach? Thanks!
Old Sep 25, 2002 | 07:50 PM
poison's Avatar
Default Re: what tool to use for polishing intake? (teal_dx)
you can use some fine wet sanding sand paper and do a little port and polish, or use a little buffer as well. i've seen both done
Old Sep 25, 2002 | 08:03 PM
GimpyAccord's Avatar
Default Re: what tool to use for polishing intake? (poison)
on a previous project i used a dremel with various grit wheels of fine sandpaper, and finally some tripoli compound and a buffing wheel to get that mirror shine on the exhaust side.
intake side same thing, except i left it a lil roughed up to help promote fuel/air mixture.
Old Sep 25, 2002 | 08:42 PM
kinesistech's Avatar
There is a company called cratex.com. They have rotary tools for p&p. They are an abrasive rubber compound similar to extrude hone media. They're way better than sandpaper. They will give you a mirror finish if you want. You have to buy kits rather than just individual bits. They come with mandrels and everything you need. The mandrels wont go all the way to the plenum but its still worth it. Kit #778 will best suit your needs. They go for about $45. Just call them up and ask where the nearest distributor to you is. If you invest in it, polish your combustion chambers and exhaust ports to a mirror finish. Carbon has a difficult time collecting on smooth surfaces, and it'll help with exhaust scavaging.
Old Sep 25, 2002 | 09:15 PM
the DR.'s Avatar
if you're using a dremel or something similar, get the "flapper sander," it works really well.
Old Sep 25, 2002 | 10:08 PM
owen_the_soyboy's Avatar
LOL you asked what TOOL to use....
JSPECSIR
Dec 10, 2009 05:03 PM
racer76j
Mar 8, 2009 06:28 PM
youngvedder
Jan 4, 2004 01:17 PM
blackccoupe
Sep 7, 2003 07:08 PM
bluedelsol
Sep 8, 2002 03:59 PM
