89 DX wont start, kinda stumped
Old Dec 26, 2003 | 02:19 PM
Jet Black's Avatar
Default 89 DX wont start, kinda stumped
I've been rebuilding this POS for 6 months, just reconnected the gas lines.
I ran the pump a couple cycles to make sure I had gas in the lines. (Then I pulled the return line and it was wet, so I know I have gas).
I tried to start it...nothing. Engine turns but you never hear it try and start. Pretty much the same thing that you would get when unplugging the ECU.
I pulled a plug wire and put it near a ground to check for spark....I didnt have any and got a shock from holding the INSULATED spk plug wire and touching the frame.
I eventually got a spark from Cyl 1.
I changed the wires anyways with another set I had lying around, I still have spark in cylender 1, but I cant see any in the other cylenders.
This kinda rules out the ignitor, as I do get a spark...but it seems weak as I needed to get really close to a ground wtih the cable from cylender 1 to get a spark.
I pulled the plugs and they were fouled with gas.....I let it dry and tried again.
Still the same thing.
I know I have gas,
I seem to have spark....wtf?
I checked the resistance from my block to the neg batt pol and its 6 ohms, a little high....but shouldnt stop it from starting.
Clues?
Old Dec 26, 2003 | 05:10 PM
Grease Monkey's Avatar
Default Re: 89 DX wont start, kinda stumped (Jet Black)
Just cuz you get spark doesnt rule out the ignitor.. your obviously not getting enough spark..
Old Dec 26, 2003 | 06:02 PM
Jet Black's Avatar
Default Re: 89 DX wont start, kinda stumped (Grease Monkey)
From the circuit diagrams it should rule out the ignitor since the ignitor controls the current to the coils.
I fixed it....the problem was stupidity.
When I plugged the fuel lines back in, I reversed the feed and return lines.
Started on the 1st crank after I correct that
Old Dec 26, 2003 | 06:04 PM
Redline130's Avatar
Glad you got it solved
Old Dec 26, 2003 | 06:50 PM
Jet Black's Avatar
Default Re: 89 DX wont start, kinda stumped (Redline130)
me too...allthough I'm ashamed
On the bright side...I won the bet car did start on the 1st crank.
gen2_4door
Feb 7, 2010 04:08 PM
rewerbcrx
24
Mar 11, 2006 06:40 AM
jmatthews
Jan 5, 2005 01:15 PM
Trbospnkr
Dec 29, 2003 09:46 AM
Peligro
Jun 21, 2003 06:43 PM
