VAFC malfunction....PLEASE HELP
Old Dec 25, 2003 | 09:41 AM
ultimatehonda's Avatar
Default VAFC malfunction....PLEASE HELP
Ok so me and my friend were installing a vafc in his 2001 GSR and we wire up the vafc and everything is good to go. So we go on a test drive and the CEL goes on, and it would not let us rev pass 5k. So we run the code and its code 22(vtec malfunction). So we go back and check all the wires, every wire is to spec and none of them are loose. We reset the ecu and go on a test run. Same thing happens again. So this time we switched the actual vafc unit with the one I have in my car and connected it to the existing wiring in the GSR. We go on a test run and hit vtec numerous of times and it was perfect. No CELS at all with the other unit. Is there anyways of fixing the malfunctioning unit or has this happened to anyone esle. TIA
Old Dec 25, 2003 | 09:32 PM
mastarolla's Avatar
Default Re: VAFC malfunction....PLEASE HELP (ultimatehonda)
01 GSR has VTM signal wire.....hook up the VTM to the VAFC harness, then re-initialize the unit to run with pressure sensing vtec.
Im assuming that the car runs ok on the low cam side of things and the vtec may or may not work occasionally and once the CEL comes on the motor wont go into high cam?
Old Dec 26, 2003 | 07:25 AM
BoBo Racing's Avatar
Default Re: VAFC malfunction....PLEASE HELP (mastarolla)
the vtm wire is hooked up and yes the car runs perfect in low cams but as soon as u engage high cams the CEL will come right on and then the car will not rev past 5k at all so right now i reseted the ecu so the CEL will not come on right now and im just driving normal shifting at 3 k so that i wont throw it on. im still trying to figure it out thanks
Old Dec 26, 2003 | 11:43 PM
mastarolla's Avatar
Default Re: VAFC malfunction....PLEASE HELP (rsx veilside)
i forgot what the harness is like on the VAFC..... damn!
there should be input and output for the vtec signal right? If you used male/female connectors, make sure that the connections to the wires are cool and that the connectors are fully connected. Make sure you have the input and output connected to the correct section of the wire.
Did you initialize the VAFC to use the pressure vtec also, or initialize the rest correctly while on that topic? that will cause the ecu to flip out bigtime! I had the VTM wire disconnected on my e-manage and my car would cross over into vtec at normal rpm (2500 for vtec-e) and then attempt to cross again later at like 4500... that was some funny ****.
Old Dec 27, 2003 | 02:35 PM
we did not use connectors at all we sauttered the wires and we triple checked all the wires the wires are all connected properly and that when we switched the controller with my friend, the car would run perfect no light or anything and then as soon as i put mine back on it threw a CEl real quick thanks though
Old Dec 27, 2003 | 05:25 PM
mastarolla's Avatar
its gotta be something with the vehicle harness then...its the only other thing that would make sense to me
BMac86
Oct 16, 2003 08:14 PM
S2KP
Oct 8, 2003 07:08 AM
.Beaver
28
Nov 19, 2002 04:31 PM
homer
Mar 8, 2002 08:50 PM
