problems with cluster guage
Old Dec 23, 2003 | 08:04 AM
92lscivic's Avatar
Default problems with cluster guage
I have a 92 civic HB with an LS motor....my car was recently hit in the front right corner...knocking out my corner lamp...i went to use my right turn signal and as soon as i did my whole cluster guage went out and i have no turn signals all the way around. I have searched everywhere for the fuses for the cluster and turn signals but still no luck. Fuse box under the hood has no fuses for them nor does the box under the console. does anyone have any suggestions...please help...thanks!!!!
Old Dec 23, 2003 | 10:28 AM
freezin_in_MN's Avatar
You know where the fuse panel inside the car is right? On the back of the little door for it, there should be a diagram showing what fuse operates what function. The one you want is (i think) instrument cluster, tail lights, turn signals.
Old Dec 24, 2003 | 05:52 AM
92lscivic's Avatar
Default Re: (freezin_in_MN)
yeah i checked that one and the fuse is fine
Old Dec 24, 2003 | 02:12 PM
Kendall's Avatar
Make sure that one of the wires from the accident area isn't accidentally grounding out somewhere. This could cause certain things to stop operating without blowing a fuse.
Old Dec 26, 2003 | 08:00 AM
92lscivic's Avatar
Default Re: (dc231)
i checked all wires and nothing is grounding out...i have no idea what else to check??
Old Dec 26, 2003 | 09:34 AM
4crx4me's Avatar
Default Re: problems with cluster guage (92lscivic)
I'm just guessing here, but isn't there a relay on the inner fender.
I can't remember what it's for though. Headlights? Flashers? Got a helms?
Old Dec 27, 2003 | 06:48 AM
doublejz's Avatar
Default Re: problems with cluster guage (4crx4me)
yea there is a relay on the passenger side right behind the head light, check that out
Old Jan 4, 2004 | 03:25 PM
GoT HaTcH's Avatar
Default Re: problems with cluster guage (doublejz)
check your reverse lights fuse.. it could be that
silverboost
Jan 2, 2007 01:52 PM
timntam
Feb 3, 2006 11:10 AM
JDMlyfestyle
Nov 20, 2005 07:21 PM
rodimus
Aug 3, 2005 06:57 PM
SiR HatchAlot
Mar 28, 2004 09:31 AM
