Help...Surging idle.
Old Dec 23, 2003 | 04:42 AM
dustinsterk's Avatar
Default Help...Surging idle.
Hey everyone, I have a 92 Civic CX with a sir2 swap. I was wondering what could cause a surging idle. The coolant does not seem to have any air in it, and the idle jumps from 1k to 3k. Evey now and then it will level out and idle at 2300. If anyone has any idea what is going on please let me know.
Thanks,
Dustin
Old Dec 23, 2003 | 01:42 PM
lilredhatch's Avatar
Default Re: Help...Surging idle. (dustinsterk)
hope this helps
http://www.hondaswap.com/articles/viewer.php?id=55
Old Dec 23, 2003 | 05:28 PM
Default Re: Help...Surging idle. (lilredhatch)
Thanks for the info man....i will keep you all posted.
Old Dec 23, 2003 | 09:11 PM
xsiv's Avatar
If that don't help, there is plenty on irratic idle in the archive; just do a search, you'll be surprised.
Old Dec 27, 2003 | 08:04 PM
Default Re: Help...Surging idle. (xsiv)
still having problems.....IAC was fine.....any other suggestions??? Could it be the intake manifold gasket?
Old Dec 27, 2003 | 08:13 PM
gumbii's Avatar
it could be the intake manifold gasget....
spray some WD-40 or carb cleaner where the intake conects to the heads.... if the idle goes up... you have a leak....
you could also take off the throttle body and check the idle valve.... maybe its unscrewed or loose....
its the part of the throttle body that the anti freeze goes thru....
you should also do a hose and throttle body check... cover your throttle body and see if the idle changes... and pinch the air hoses....
i had the same problem... and oscar jackson from jackson racing told us how to fix it.....
Old Dec 31, 2003 | 04:10 AM
Default Re: (gumbii)
gumbii you are the man!!! All problems solved!
norcalB18
Dec 7, 2015 10:24 AM
FloGgY
Apr 12, 2008 01:13 PM
B18CivicEH2
Jan 4, 2007 03:07 PM
94SHOWLS
Feb 17, 2005 12:31 PM
steve_s
Jan 22, 2003 02:06 AM
