intake manifold install gone wrong...hydrolock???
Old Dec 22, 2003 | 05:14 PM
s o h c's Avatar
Default intake manifold install gone wrong...hydrolock???
well i was stupid and did not label anything while swapping in my edelbrock intake manifold. well after the install, while i was adding coolant, i saw a leak. it was than that i realized that i had switch a vaccum and coolant line, so i proceeded to remove the intake manifold and found it was full of coolant . but coolant only entered the runner to cylidner 1, the rest were dry. i did not start the car and i have since used a towel to soak up what i could by sticking my fingers into the runner. so my question is, should i be worried??? i plan on letting it dry and reinstalling the manifold tomorrow
Old Dec 22, 2003 | 05:30 PM
fulldragcrx's Avatar
even though it sounds stupid, it happends all the time. Just to make sure that no coolant got in the motor i would remove the plugs and crank the motor over several times. just to make sure. When i say "Crank" I mean with the Key, not by hand. Reinstall the intake and start the car, drive for a day and then change your oil.
Old Dec 22, 2003 | 05:33 PM
Kendall's Avatar
Default Re: (fulldragcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fulldragcrx &raquo;</TD></TR><TR><TD CLASS="quote">even though it sounds stupid, it happends all the time. Just to make sure that no coolant got in the motor i would remove the plugs and crank the motor over several times. just to make sure. When i say "Crank" I mean with the Key, not by hand. Reinstall the intake and start the car, drive for a day and then change your oil.</TD></TR></TABLE>
Exacly. There are few things worse than a hydrolock so be sure to take all the time necessary to properly sort everything out.
Old Dec 22, 2003 | 05:37 PM
s o h c's Avatar
Default Re: (dc231)
thanks guys
Old Dec 22, 2003 | 05:43 PM
We are here to help.
let us know how you like your intake mani. when you get it going.
Old Dec 22, 2003 | 08:21 PM
RiceNmotioN's Avatar
Hahaha!!! well, not laughing at you.. My cousin did the same thing when he tried put a 94 EX IM on his 98 DX motor. He couldn't figure out what was wrong so he put his stock IM back on. I remember trying to figure out what he had done. We kept pouring in the coolant but had no clue where it went. When I saw it comming out of his throttle body, I just busted out laughing. Anyways, I fixed the problem and got most of the liquid out. He's lucky that engine is still running okay.
Old Dec 22, 2003 | 08:25 PM
leadfoot78's Avatar
Default Re: (RiceNmotioN)
Also take the ECU fuse out when u are cranking the motor so it dosn't sparay fuel, no need for a fire hasard.
Old Dec 22, 2003 | 09:50 PM
2+2=5's Avatar
Default Re: (leadfoot78)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by leadfoot78 &raquo;</TD></TR><TR><TD CLASS="quote">Also take the ECU fuse out when u are cranking the motor so it dosn't sparay fuel, no need for a fire hasard. </TD></TR></TABLE>
just like how you do the compression test, panel to the ground, all spark plugs out and try crank it, it's not likely but it's worth a try.
water=non-compressable
lv2racehondas
Honda CR-V & Element
Mar 15, 2019 11:01 AM
holmesnmanny
Jun 9, 2012 11:33 AM
aznevanchoi
Aug 9, 2007 07:36 AM
lude27
May 12, 2007 12:30 PM
