Skunk2 kit ball joint "Boot"
Old Dec 22, 2003 | 03:24 PM
Vitt1's Avatar
Default Skunk2 kit ball joint "Boot"
I tore my Skunk2 camber kit ball joint boot while trying to separate the ball joint with one of those forks. Does anyone know if I can replace it with an OEM boot, or how bad is it if I don't use the boot? I believe the ball joint is made of polyurethane as opposed to the rubber OEM pieces. TIA.
Old Dec 22, 2003 | 03:34 PM
VTECorona's Avatar
Default Re: Skunk2 kit ball joint "Boot" (Vitt1)
I believe skunk2 sells just the ball joint because of this. Give them a call or call some shops.
Old Dec 22, 2003 | 04:28 PM
Vitt1's Avatar
Default Re: Skunk2 kit ball joint "Boot" (VTECorona)
I called them up. They sell the ball joints alone for ~$26, but there are certain shops that sell OEM boots that cost a couple bucks. So, I wanna see if I can get one of those first since the ball joint is practically new.
Old Dec 22, 2003 | 08:13 PM
JDMHN8's Avatar
I put the Energy Suspension boots over the Skunk2 boots when I put those arms on a friends car. They will also work by themselves, but they don't seal as well...
Old Dec 22, 2003 | 10:03 PM
Vitt1's Avatar
Default Re: Skunk2 kit ball joint "Boot" (JDMDA9)
Thanks for the info, I'll look for some ES tomorrow. But what do you mean they will work by themselves? The ball joint alone without any boots?
The tear is not really bad, and I wonder if they'll last a while since they're poly.
Old Dec 23, 2003 | 07:58 AM
JDMHN8's Avatar
I meant the ES boots can work by themselves, but by nature of there design, they don't seal as well as the Skunk2 boots. I recommend using the ES boots over the Skunk boots for maximum sealing.
Old Dec 23, 2003 | 11:44 AM
Vitt1's Avatar
Got it, thank you.
civichb98
Suspension & Brakes
20
Aug 29, 2010 10:25 AM
Pondus
Suspension & Brakes
Mar 17, 2009 08:51 AM
4drRacer
Oct 12, 2003 09:55 PM
EE_Chris
43
Sep 17, 2002 05:10 PM
EE_Chris
Aug 26, 2002 03:28 PM
