tps sensor!!
Old Dec 22, 2003 | 02:31 PM
killa_lude's Avatar
Default tps sensor!!
how do i get he oem tps sensor off of a h22 tb?? theres no nut or anything....
Old Dec 22, 2003 | 03:12 PM
jerseydevil's Avatar
The tps on my gsr broke and I was also surprised by the lack of nuts. It apears to be rivited on they are actually screwed with the head snapped off. I used a very small punch to start it turning and was able to put some vice grips on it and finish it what way. It new tps was put on with a normal screw so I could adjust it and then tighten it.
Old Dec 22, 2003 | 05:16 PM
killa_lude's Avatar
Default Re: (jerseydevil)
yeah thats fucked up why the heads of the nuts are broken off...was it a pain to get them unscrewed?
Old Dec 22, 2003 | 05:52 PM
lilredhatch's Avatar
Default Re: (killa_lude)
A dremel tool works like a charm with a tps. Just grind in between the rivets with a disc on the dremel and remove with a flathead screwdriver
Simple as that
Old Dec 22, 2003 | 06:19 PM
Kamin's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude &raquo;</TD></TR><TR><TD CLASS="quote">yeah thats fucked up why the heads of the nuts are broken off...was it a pain to get them unscrewed?</TD></TR></TABLE>
its because you arent supposed to touch the TPS sensor. it comes calibrated from the factory and should never need to be reset.
but yes, a dremel and a flathead works great.
Old Dec 22, 2003 | 09:41 PM
killa_lude's Avatar
Default Re: (Kamin)
is there a place that sells aftermarket h22 tps sensors?
Old Dec 22, 2003 | 09:49 PM
sirminder's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by killa_lude &raquo;</TD></TR><TR><TD CLASS="quote">is there a place that sells aftermarket h22 tps sensors?</TD></TR></TABLE>
Arent pretty much all TPS all the same?
Old Dec 22, 2003 | 09:59 PM
killa_lude's Avatar
Default Re: (sirminder)
you would think i was just wondering...
Old Dec 23, 2003 | 11:45 AM
4crx4me's Avatar
I just posted in another thread about an article I read somewhere, where you can get a TPS from a Honda motorcycle dealer. The honda car dealers only sell them with the throttlebody.
Try calling one to find out. The TPS's are all the same.
Old Dec 23, 2003 | 01:36 PM
killa_lude's Avatar
Default Re: (4crx4me)
ok cool, yeah i went to the honda dealership and you have to buy the whole tb....
Old Dec 23, 2003 | 01:48 PM
Ebay has them sometimes. Or try a junkyard or salvage yard
I got one from ebay before, worked just fine
Old Dec 26, 2003 | 04:52 PM
killa_lude's Avatar
Default Re: (lilredhatch)
i think i'm going to try to get my old tps off of my oem tb off first...
408h22a1
Feb 27, 2013 07:41 PM
CRX30436
Feb 6, 2008 07:00 PM
kornerk12
Jun 15, 2007 04:01 AM
JUN_H22A
Jan 12, 2006 09:25 AM
JDM MonopolyMan
Oct 15, 2005 12:53 PM
