what sleeves to use...hmm
Old Dec 20, 2003 | 10:54 AM
gumbybum's Avatar
Default what sleeves to use...hmm
im getting my c1 block Monday and im going to have new sleeves put in it. The only problem is im not sure what sleeves i should get. i think OEM should be fine since im only going to be running like 10.7 cr. But I might go higher depending on what pistons are available and if i can ever make up my mind. Another thing i need help with is i might run a b16 head on it or should i keep looking and try to find a gsr? I know combustion chamber is a little bit bigger on the b16 but not sure what to do? Thanks for all of your help guys
Old Dec 20, 2003 | 11:28 AM
ExospeedAMcrx's Avatar
Default Re: what sleeves to use...hmm (gumbybum)
are you planning to go bigger bore? or turbo later on?
Check out the sleeving service we provide.
Wil
Old Dec 20, 2003 | 11:30 AM
97Civic-R's Avatar
Default Re: what sleeves to use...hmm (exospeedAMcrx)
Exospeed gets my thumbs up....good people
Old Dec 20, 2003 | 05:36 PM
Kataku2K3's Avatar
Default Re: what sleeves to use...hmm (97Civic-R)
You're definately fine at 10.70:1 on stock sleeves but as exospeedAMcrx said, if you want to go with a bigger bore or are planning on FI later on down the road you may want to consider sleeving... This is my order, company wise... #1 = AEBS, #2 = RS, and #3 = Golden Eagle Mfg... As for cylinder heads it's really a matter of preference... Typically we use the P72 (GSR) cylinder head with most of our motors whether they start as a straight B18C1 or not... All the flow charts I've seen have shown that the PR3 flows and makes more power midrange where as the P72 is a little better up top... Just my $0.02, Good Luck
Old Dec 20, 2003 | 08:45 PM
gumbybum's Avatar
thanks so much guys. i may go fi later down the road but for now im staying na. ill just use oe sleeves too. Also i think ill just get the b16 head just in because it will be easier to get for me. thanks again
fastasssr20
Jan 26, 2012 07:43 AM
master honda tech
Aug 24, 2005 09:32 AM
JDcompman
Apr 6, 2004 02:10 PM
SiRkid
Jan 13, 2003 10:54 PM
Ehron
May 28, 2002 10:04 AM
