Having Fifth Gear Problems
Old Dec 19, 2003 | 06:47 AM
sploo01's Avatar
Default Having Fifth Gear Problems
I have a 2000 Civic Si. When ever i shift into Fifth gear i have to hold it in gear while i engage the clutch. if i decelerate any time after i am in the gear it will pop out of gear this has been an escalting problem for a few months and only getting worse. If anyone knows what could possibly be wrong with it feel free to let me know before I have to take it to the dealer.
Old Dec 19, 2003 | 08:38 AM
Jimmy's Avatar
Global Moderator
Someones not a good driver
Could you your clutch but I'm almost %100 sure its your synchros
Old Dec 19, 2003 | 08:55 AM
Devlins 91LS's Avatar
Default Re: (USDMDC2)
Its the tranny, change the transmission fluid with GM Syncromesh Friction Modified and hope it goes away. it fixed my third gear grind after like a week.
Only downside, you're gonna need like 3 quarts, and they're like $15/each
Old Dec 19, 2003 | 02:10 PM
torr's Avatar
Default Re: (Devlins 91LS)
yeeah it's your tranny, my tranny did the same thing, after a week it wouldn't even go into reverse.
Old Dec 19, 2003 | 05:28 PM
omega11855's Avatar
LOL gm synchro mesh isnt gonna stop pop out but you could try its only 30ish bucks just take apart your tranny you probably burned 5th gear it doesnt grind any other gears? u can do 5th yourself if your careful and patient
Old Dec 20, 2003 | 09:37 AM
Default Re: (omega11855)
Syncromesh stopped pop-out in my buddies ls
Old Dec 20, 2003 | 08:41 PM
Muckman's Avatar
Moderator in Chief
Synchromesh solves all!
It will wash your car and bump up the output a little.
Old Dec 21, 2003 | 08:16 AM
PupaScoopa's Avatar
Default Re: (Muckman)
Sounds more like a bent shift fork.
Old Dec 23, 2003 | 07:20 AM
sploo01's Avatar
Have any tips on where i can find info on how to replace Fifth? I have taken it to the Dealer and they are telling me to remove the short throw shifter and if that doesn't work I should replace the entire Tranny through them their ticket depending on the tranny i want is between 2 & 5 Grand. For that i could by A Motor, Tranny, and Ecu. I might be screwed.
Old Dec 23, 2003 | 10:41 AM
PupaScoopa's Avatar
Default Re: (sploo01)
Most dealershipos won't service transmissions, they can troubleshoot and replace the whole thing if necessary. Try a local transmissions shop, they're not scared to open it and find out what's going on.
Old Dec 23, 2003 | 11:40 AM
Aceman64's Avatar
Default Re: Having Fifth Gear Problems (sploo01)
Have you tried changing the fluid? Have you checked seals to see if you are leaking fluid? I had a problem with a tranny coming out of 5th gear. Ended up being a ripped axle seal.
-Ace
Old Dec 23, 2003 | 12:00 PM
b20turbojason's Avatar
i was haveing the same problem and was cause i was low on tranny fluid. i put a quart in and no more problem. but check to see if you have a leak like what Aceman64 said. you shouldn't just be low on fluid it is leaking out somewhere.i have a hairline crack in my tranny that is why it leaks.
slayersluck
Jan 13, 2007 11:36 PM
.paul
Jan 12, 2007 12:35 PM
The Phil
Mar 18, 2005 08:27 AM
sshaikh01
17
Mar 6, 2003 06:27 PM
is3oo
Jun 6, 2002 10:10 PM
