Power from free mods
Old Dec 18, 2003 | 11:55 PM
ryanstev's Avatar
Default Power from free mods
I have a 3rd Gen Prelude, carburettored, 110hp. I was wondering how much power each of the following free mods would give me.
Disabling the EGR.
Coolant bypass mod.
Advancing the timing. I'm thinking 2 degrees, unless someone knows of a better figure.
I'm only interested in doing the timing advancement, since it's the easiest there and would give the most power.
If I could get an approximate horsepower or percentage increase, that would be great.
Old Dec 19, 2003 | 12:00 AM
B16OnTop's Avatar
Default Re: Power from free mods (ryanstev)
weight reduction works wonders, along with removing useless **** like ps and a/c
Old Dec 19, 2003 | 12:08 AM
ryanstev's Avatar
Default Re: Power from free mods (B16OnTop)
I agree, but I like my power steering, A/C is good when it works, need to recharge it.
Old Dec 19, 2003 | 12:31 AM
B16OnTop's Avatar
i thought i liked my ps, but then i took it out and reaqlized i liked my car alot better w/o it, you should take it out for a day and if you dont like it put it back in, its just one belt and takes maybe 10 minutes to remove
Old Dec 19, 2003 | 06:32 AM
Mike_C's Avatar
Weight is your enemy, you're simply not gonna find any power in that motor without some FI. Take out your AC and PS, will net you around 100lbs and free up a few ponies.
Old Dec 21, 2003 | 08:44 AM
PupaScoopa's Avatar
Cooland bypass may cuase more trouble than good. May freeze up the carb open or closed.
Old Dec 21, 2003 | 12:46 PM
Kendall's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B16OnTop &raquo;</TD></TR><TR><TD CLASS="quote">weight reduction works wonders, along with removing useless **** like ps and a/c</TD></TR></TABLE>
AMEN brother. On a 3rd gen 'lude you should probably be able to put the car on about a 400 pound diet before it starts getting dangerous.
Old Dec 21, 2003 | 05:52 PM
TheGSRGuy's Avatar
Default Re: Power from free mods (dc231)
Do not disable the EGR system, it actually improves your power output and reduces emissions.
I would go for weight reduction, it is free and usually reversible.
a1320honda
Sep 27, 2010 06:24 PM
92ehatch
35
Aug 3, 2005 12:58 PM
STREETWERKZ
Jun 10, 2004 08:14 PM
5thgencivic
May 2, 2003 07:14 PM
HybridGSR1
Sep 26, 2002 02:31 AM
