Motor Mounts..Is this correct??
ok, 5 mounts total..
1 Rear mount-near fire wall (the bitch one)
2 Upper side mounts
2 Lower side mounts
From what I've heard, Prothane only makes the top 2 mounts and Energy suspension makes the Lower mounts...does prothane make the rear one??
Also the top two side mounts have to be pressed out or tourched out....or cut out, for the cutting part of it, does anybody have pictures of the part i have to cut?
Also can anybody please tell me the part numbers for the prothane uppers and Energy suspension lowers...Red mounts please...
I have read the past posts, and would of gone with jimfab lowers but he couldn't get them to me before dec 23.
Thanks guys.
2 Upper side mounts
2 Lower side mounts
Thanks guys.
The prothane kit I purchased came with the rear insert as well as the two upper mount inserts (on the driver side you get your choice of two different inserts, one is a street disc and the other is the race disk). The driver side mount has to be pressed out, I recommend you take it to a machine shop and have them do it (its really inexpensive). I also have the energy kit, which If I remember correctly came with the two lower sub mount inserts and also a rear mount insert (so if you buy both kits you will have one extra rear mount insert, though you may be able to buy certain inserts separately, but I personally do not know if you can), hope this helps! get me back if I didnt answer any of your questions...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c-rDC2 »</TD></TR><TR><TD CLASS="quote">The prothane kit I purchased came with the rear insert as well as the two upper mount inserts (on the driver side you get your choice of two different inserts, one is a street disc and the other is the race disk). The driver side mount has to be pressed out, I recommend you take it to a machine shop and have them do it (its really inexpensive). I also have the energy kit, which If I remember correctly came with the two lower sub mount inserts and also a rear mount insert (so if you buy both kits you will have one extra rear mount insert, though you may be able to buy certain inserts separately, but I personally do not know if you can), hope this helps! get me back if I didnt answer any of your questions...</TD></TR></TABLE>
thanks!..so i will get the prothane rear one too...anybody have part numbers??
Alex..be ready!..........................shrimp.
Maybe your answer is in one of these?
https://honda-tech.com/zerothread?id=680862
https://honda-tech.com/zerothread?id=178918
https://honda-tech.com/zerothread?id=669125
https://honda-tech.com/zerothread?id=696980
https://honda-tech.com/zerothread?id=696365
IF not I know there is a lot of info there
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Bbasso »</TD></TR><TR><TD CLASS="quote">Maybe your answer is in one of these?
i've already read all those...but still, i need a part number for the es ones...it would greatly appriciated.
