Another B series swap problem
Well, I'm putting this turbo B16 into my 91 Civic Hatch STD with HCP mounts. Unfortunately I'm having the worst time getting the rear mount to line up properly. I just wanted to see if anyone has had a similar experience and if they knew a possible solution to the problem. Any insight is much appreciated.
Which rear mount bracket are you using? The proper one should be a 90-93 Integra rear bracket. Also the rear mount should be moved toward the passenger side on the other set of nearby bolt holes.
91BlueEF9
Sep 8, 2007 07:00 AM
ExodusJKD
Mar 25, 2005 10:16 AM
