Just got 5th gen? what problesm to look for?
Old Dec 16, 2003 | 03:27 PM
Luchini's Avatar
Default Just got 5th gen? what problesm to look for?
I just bought a 00 lude 5spd with about 32,000 miles on it. Just wondering what kind of normal wear and tear items I should replace besides oil? Do any of you guys notice when you are redlining and shifting from 2nd to 3rd the tranny feels like it grinds? I dont hear it but i can kinda feel it and it only happens on the 2 to 3 shift at redline not when i normally shift at 3k.
Old Dec 16, 2003 | 04:07 PM
PrecisionH23a's Avatar
Default Re: Just got 5th gen? what problesm to look for? (Luchini)
The grind is your synchro's going to hell. Very typical problem with the H series transmissions. Try using GM synchromesh transmission fluid, a few guys on the board had the same problems you are describing and it fixed it. As far as a permanent fix, the only real way to fix it for good is tearing the tranny down and replacing the worn synchro's.
Old Dec 16, 2003 | 07:06 PM
Luchini's Avatar
Default Re: Just got 5th gen? what problesm to look for? (GudeH23a)
Damn that sucks. I wonder why h series trannies are so weak. How much would taking the tranny apart vs. buying a new tranny cost?
Old Dec 16, 2003 | 07:20 PM
Luchini's Avatar
Does anybody know where to get the gm synchromesh? or what the part # is? I cant seem to find a place to buy it.
Old Dec 16, 2003 | 07:30 PM
Wiseguy619's Avatar
you can buy it at a GM dealership.
Old Dec 16, 2003 | 10:40 PM
1SICH22's Avatar
the second and thrid gear grind is normal for most honda manual trannys...just be ready for your 2nd gear to go first..than your 3rd...
Old Dec 17, 2003 | 08:10 AM
imported204's Avatar
Default Re: (1SICH22)
Taking the tranny apart would cost a good amount, I would put some syncromesh in the gearbox right now, it seemed to help my 5th gear grind. If u do plan on taking the tranny apart i would go ahead and change all the synchros instead of having to take it apart again later.
Old Dec 17, 2003 | 09:49 AM
godslude's Avatar
hi i was wondering what you meant by "be ready for your 2nd gear to go first"?
i have the same problem when im switching from 2nd to 3rd gear. thanx
Old Dec 17, 2003 | 10:52 AM
98vtec's Avatar
moderator emeritus
Default Re: (godslude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by godslude &raquo;</TD></TR><TR><TD CLASS="quote">hi i was wondering what you meant by "be ready for your 2nd gear to go first"?
i have the same problem when im switching from 2nd to 3rd gear. thanx</TD></TR></TABLE>
he means be ready for the 2nd gear synchro to be worn out before the 3rd gear synchro. Meaning you are going to prolly end up replacing the 2nd gear synchro first.
Old Dec 17, 2003 | 11:16 AM
dankbudz11357's Avatar
Default Re: (98vtec)
mine is grinding going into 5th only. so when i shift into fifth i double clutch it and it doesn't grind. need to get me some gm synchromesh, should hold me off until i rebuild the tranny.
when i had my 89 hatchback with a b16 in it, i had grinds going into 2nd and 3rd. now i'm just wary of trannys that come from japan, should have rebulit it before i put it in, damn.
Old Dec 17, 2003 | 07:36 PM
00preludepearl's Avatar
Default Re: (dankbudz11357)
Yeah mines grinded twice in a power shift from 2nd to 3rd....but i think it was my fault, let the clutch out too soon...i have 43K on my lude....and the tranny is in great condition no problems getting in into gear....and really no shifting probs......
Old Dec 18, 2003 | 12:51 AM
Wiseguy619's Avatar
Default Re: (00preludepearl)
i haven't driven my lude in so long i forgot if i even had any grinds.
Old Dec 18, 2003 | 02:44 AM
Luchini's Avatar
So do you guys think this is just a minor problem that synchromesh should fix? Other then the 2nd to 3rd powershift the tranny works well for the most part. Sometimes it doesnt wanna shift into 1st or R but it usually works for the most part.
eric416
Dec 5, 2006 01:16 AM
plonger
Apr 23, 2006 10:48 AM
b16a2-t *turbocoupe*
Feb 28, 2006 10:26 AM
ixcryxblood
Oct 3, 2004 01:42 PM
MasterSaif
Apr 28, 2004 03:44 AM
