Hybrid CRX axle question
Old Dec 13, 2003 | 04:50 PM
gatesrex91's Avatar
Default Hybrid CRX axle question
Need help from the swap pros. I searched, and couldnt find any definative info. I am planning on buying a Y1 tranny, i currently have an S1 tranny (in my CRX with B16a) and i have 90-93 integra axles. I need to know if you can use these axles with the Y1 or if you would need different axles, cause someone mentioned to me that i might not be able to use my current axles if i switch to a Y1. Any info or clarification on this would be great.
PS part of my confusion is from the hasport site that sells different EF axles for the Y1 then the ones that are used for the J1/S1/Ys1, so i was wondering if the shafts in the Y1 are different then all other B cable trannys which would lead to my integra axles not working.
Thanks
Tyler
Old Dec 13, 2003 | 05:26 PM
Newman's Avatar
New User
Default Re: Hybrid CRX axle question (gatesrex91)
Same ****. Just reuse the existing axles & intermediate shaft that's already on your car. Now, if you have a Y1 LSD tranny, then it's a different story. But otherwise, stick with the existing axles AND intermediate shaft that you are using now. What the other person was thinking was that the Y1 intermediate shaft is longer than the A1/S1/J1 intermediate shaft, so a shorter driver side (88-89 Integra) axle would need to be used. But if you just switch out the transmissions only, then keep everything else the same, assuming that it's not LSD because then you'll need a shorter passenger side axle since the LSD diff is wider.
Old Dec 13, 2003 | 05:30 PM
gatesrex91's Avatar
Default Re: Hybrid CRX axle question (Newman)
so i would need to remove the intermediate shaft from my tranny and use that instead of the one that comes with the Y1? Is this process difficult?
Old Dec 13, 2003 | 05:35 PM
Newman's Avatar
New User
Use the one that you orignally have. Do NOT use the one from the Y1, as it's longer, unless you really want to... then you'll have to change your driver side as well. It's a easy as 3 14mm bolts to undo to get the intermediate shaft out of the transmission.
Old Dec 14, 2003 | 12:25 PM
curt801's Avatar
so i currently have a ys1 and i am going to switch to a y1 w/lsd so what passenger side axle would i use. the ys1 has a grind in third that is why i am switching to the y1. plus the y1 has lsd.
Old Dec 15, 2003 | 06:31 PM
curt801's Avatar
Old Dec 17, 2003 | 08:52 AM
gatesrex91's Avatar
Default Re: (b1788crx)
hasport sells their own axles for the Y1 lsd tranny swap, http://www.hasport.com
Check and see if that is what you are looking for.
2x0
16
Sep 21, 2017 05:13 AM
G0crxG0
Jul 9, 2006 03:19 PM
GSRCRXsi
Dec 10, 2004 08:13 PM
Eggman
Feb 8, 2002 10:45 AM
