My turbo hits the block?
Old Dec 12, 2003 | 09:11 AM
booscivic's Avatar
Default My turbo hits the block?
Will that be a problem just a little bit of the compressor? SOHC t3/t4e 60a/r
Old Dec 12, 2003 | 09:20 AM
booscivic's Avatar
anybody?
Old Dec 12, 2003 | 09:25 AM
psycho_civic's Avatar
same **** happ to me.. i cut off some of the webbing with a grinder... **** cut it like butter
Old Dec 12, 2003 | 09:33 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Default Re: (psycho_civic)
You certainly don't want to tighten it down all the way if it is hitting the block 'cause that could really mess something up. Can you just use a manifold flange off ebay with a second gasket and longer studs to move it away from the block another 1/2" or so? That might work.
Old Dec 12, 2003 | 09:39 AM
BioXide02's Avatar
Default Re: (tjbizzo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tjbizzo &raquo;</TD></TR><TR><TD CLASS="quote">You certainly don't want to tighten it down all the way if it is hitting the block 'cause that could really mess something up. Can you just use a manifold flange off ebay with a second gasket and longer studs to move it away from the block another 1/2" or so? That might work. </TD></TR></TABLE> Do you have pictures of this?
Old Dec 12, 2003 | 09:49 AM
booscivic's Avatar
It tightends dowm just fine, nut the compressors corner hit the blocka little bit
Old Dec 12, 2003 | 10:05 AM
MotorMatrix.com's Avatar
I am a bad person
Default Re: (booscivic)
grind it a little. dont worry its safe to do. I had to do it with my revhard log and 62-1 turbo.
Old Dec 12, 2003 | 10:10 AM
booscivic's Avatar
I already did! I dont think I cant no more, the manifold sealed fined like that, can I leave it the way it is?
Old Dec 12, 2003 | 10:11 AM
tjbizzo's Avatar
Default Re: (BioXide02)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BioXide02 &raquo;</TD></TR><TR><TD CLASS="quote"> Do you have pictures of this?</TD></TR></TABLE>
Sorry, no. But go to ebaymotor's turbocharger section and you'll see the header flanges for sale on almost every page.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by booscivic &raquo;</TD></TR><TR><TD CLASS="quote">It tightends dowm just fine, nut the compressors corner hit the blocka little bit</TD></TR></TABLE>
The problem is that you might be putting a WHOLE LOT of stress on the compressor housing, center cartridge, exhaust housing, manifold, etc. Maybe enough to deform it or crack it now, or later when it heats up, or possibly cause gasket sealing problems. It's just plain bad mojo to risk something like that. I'm just trying to suggest a fairly cheap, easy, obvious, reversible solution, so long as it doesn't push the turbo into the radiator with the extra 1/2". Good luck
Old Dec 12, 2003 | 11:08 AM
booscivic's Avatar
Good point!!!!
Modified by booscivic at 2:27 PM 12/12/2003
Old Dec 12, 2003 | 11:55 AM
ItsStockOfficer's Avatar
IN my experiance, both the comp housing and block don't mind losing a bit of material. But be careful....and pick up and use and extra exhaust mani gasket or 2, thats another 2mm to be gained.
Old Dec 12, 2003 | 11:59 AM
Boltz's Avatar
Default Re: (ItsStockOfficer)
those plates that extend the manifold are supposed to leak. i wouldnt do it.
also im suprised no one has asked what manifold you are using?
Old Dec 12, 2003 | 01:18 PM
Bailhatch's Avatar
Default Re: (FourceFed)
You gotta grind the block, all the spacer crap is not good for reliability because you would have 4 more seals that need to stay intact and you have moved the turbo away from the block, giving it more leverage to yank on the studs. I would just grind it until you have at least 1mm of clearance to allow for any expansion and be done.
Old Dec 12, 2003 | 01:37 PM
mattssi's Avatar
Is there no way for you to possibly clock the turbo? you said it was hitting a bolt? POssible move it a little and gain the necessary space?
Old Dec 12, 2003 | 02:09 PM
inspecta83's Avatar
Default Re: (mattssi)
i had to flip my turbo around so that the intake side of the turbo is on the drivers side
Old Dec 12, 2003 | 02:14 PM
99B16Si's Avatar
try rotating the turbo a bit, just make sure your drain is on the bottom and feed is on top. i didnt have to gring my block at all to get my t3/t4e to fit(with is with a revhard manifold)
Old Dec 12, 2003 | 02:29 PM
booscivic's Avatar
I already have tried rotating it still hits, and Im afraid to shop any of the part where is hitting right now!!!, is acutally block not on one of the sides.
Old Dec 12, 2003 | 02:37 PM
racinskittle's Avatar
I had the same problem. I had RenoRacing make me a manifold. He did it for a great price and was really helpful. If things go south, talk to him .
But on one side, the turbo actually wont it. Put the compressor housing on the drivers side. It shouldn't hit the block then. But if you're going internal wastegate, you'll have some clearance issues. Also, making the DP will require some sharp bends as well.
It should work on the drivers side though. Keep us updated.
Old Dec 12, 2003 | 02:39 PM
booscivic's Avatar
I cant because want to keep A/C, freaking compressor housing is to big!!!
Old Dec 12, 2003 | 02:40 PM
can u clock the compressor down and run the piping from there? What's in the way of the A/C?
Old Dec 12, 2003 | 02:44 PM
booscivic's Avatar
Im not to sure what you are talking about?
Old Dec 12, 2003 | 02:45 PM
Keep clocking the turbo so that the outlet points down and run the piping from under there. Then use a wire mesh as a filter. (if you're willing to)
Old Dec 12, 2003 | 02:46 PM
booscivic's Avatar
Right now Im thinking running something a little bit smaller!!
Old Dec 12, 2003 | 11:49 PM
SiR Kid's Avatar
New User
Just get a $20 angle grinder from http://www.HarborFreight.com and grind it some. It's no big deal, I took a HUGE chunk off my block/webbing, and it's good to go.
TurboEK9Coupe
Nov 10, 2007 06:03 AM
VtecAdil
Jun 25, 2005 05:44 PM
CL SLeePeR
Apr 21, 2005 05:15 AM
SSBPGSR
Sep 9, 2004 07:25 AM
71 mgb
Aug 29, 2003 11:49 AM
