Rough idle and IACV?
Old Dec 10, 2003 | 10:37 PM
2000Accord5sp's Avatar
Default Rough idle and IACV?
I've seen several posts about cleaning/replacing IACV to fix idle problems. When you guys say IACV, are you talking about the EACV (Electronic Air Control Valve)? I can't think of what else IACV would be. Sorry if it was a stupid question...
Old Dec 17, 2003 | 11:03 AM
Vtec92Civic's Avatar
Default Re: Rough idle and IACV? (2000Accord5sp)
IACV intake ait control valve . . . theya re 2 different things. The IACV is located on the back side of your intake manifold depending on what motor you have . . . it should have a little screen on it when you take it off, and if that is clogged it can cause your idle to do weird things . . . just blast it with some carb cleaner, and it should be fine.
Old Dec 17, 2003 | 11:24 AM
Perfectionist's Avatar
Actually they are the same thing. Honda changed the name a few years ago for whatever reason.
Old Dec 17, 2003 | 07:20 PM
The_Todd's Avatar
Farts in the shower
Default Re: Rough idle and IACV? (Perfectionist)
Where is the IACV in a 90 cord? Looked in chiltons and its no help.
Old Dec 18, 2003 | 04:46 PM
StimpyBoy's Avatar
Default Re: Rough idle and IACV? (VRDrvr)
If it's anything like the 1992, it's on the front of the intake manifold, looking into the engine bay. There's two large valves on the front, the Fast Idle Valve and the IACV. One of them has screws on the top of it, that's the FIV.
If you unbolt the IACV, you'll see the screen, it'll be fairly obvious.
Old Dec 18, 2003 | 06:57 PM
The_Todd's Avatar
Farts in the shower
Default Re: Rough idle and IACV? (StimpyBoy)
Right on....should I try cleaning it first with some carb cleaner or just replace it?
wildoutwhitegsr
Jun 27, 2024 04:43 PM
dnbruut
Jan 12, 2007 02:38 AM
huge230
Mar 29, 2006 05:19 PM
94SHOWLS
Feb 17, 2005 12:31 PM
Lowtightcivic
Feb 1, 2004 01:38 PM
