what tools to do alignment
Old Dec 10, 2003 | 05:38 PM
nd8ch's Avatar
Default what tools to do alignment
my friends and i are going to try doing our alignment next week with the string.
What size wrench do we need to undo the nut on the tie rod?
also, do we just turn the tie rod to make changes?
Old Dec 10, 2003 | 05:51 PM
BigLoadChoakHard's Avatar
Default Re: what tools to do alignment (nd8ch)
its probably like a 16 or 17 to loosen the nut then u can use a pair of vise grips clamp them on the tie rod socket ( the end were it is threaded) and turn it or out of the tie rod end to make the adjustment
Old Dec 10, 2003 | 05:58 PM
hondafied's Avatar
om the rear its a 17 mil to loosen and a 14 mil to adjust. on the front its a 19 mil to loosen the locknut, and use an open end 14 mil to adjust, NO VICE GRIPS!!!!!!!!! also remember that unless you have a camber kit, the only adjustment is toe. good luck
Old Dec 10, 2003 | 05:59 PM
hondafied's Avatar
Default Re: what tools to do alignment (hondafied)
crap wait, on the rear its a 14 to loosen the get a hammer and pry the control arm. soory bout that.
Old Dec 10, 2003 | 06:07 PM
nd8ch's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondafied &raquo;</TD></TR><TR><TD CLASS="quote">on the front its a 19 mil to loosen the locknut </TD></TR></TABLE>
thats all i needed to know, but...what is it that you suggest me prying, the control arm in the back?
Old Dec 10, 2003 | 08:22 PM
nd8ch's Avatar
bump
Old Dec 10, 2003 | 08:24 PM
Chris y0!'s Avatar
yes in the front, loosen and thread the tie rod.
in the rear... loosen the nut (i don't know what size, we use adjustable wrenches) in front of the trailing arm, and pry the trailing arm either in or out (depending on weather you have toe in or out, obviously) with a crow bar of some sort.
Old Dec 10, 2003 | 09:13 PM
nd8ch's Avatar
Default Re: what tools to do alignment (Chris y0!)
the rear sounds like a pita, im just not gonna bother hehe
Old Dec 11, 2003 | 01:27 PM
IWearMyKswiss's Avatar
New User
hold on,..i didnt know you can do an alignment in your own garage,..anyone got a how to on this?
Old Dec 11, 2003 | 06:51 PM
dfoxengr's Avatar
Default Re: what tools to do alignment (WiDeBoDyEK)
alignment rack...
trust a shop to do it, its only like 40$
Old Dec 11, 2003 | 07:53 PM
nd8ch's Avatar
Default Re: what tools to do alignment (hybridvteceg)
half the time i get mine done at 40+ bucks, its still not straight. They're charging like 70 bucks no a days, plus, i dont intend on spending that much if i gotta keep changing my alignment. and lifetime alignments have a limit on the amount you can do per year...so...thats not gonna work for me =/
Old Dec 11, 2003 | 10:35 PM
New User
i want to see a how to on this,..or atleast someone write a quick howto
Old Dec 23, 2003 | 12:26 AM
nd8ch's Avatar
Default Re: (WiDeBoDyEK)
i dont know how you guys could use anything but a 22 mm wrench to open then lock nut unless you have adjustable wrenches...cause mine is a 22 mm jam nut!
Old Dec 23, 2003 | 12:51 AM
tominos's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by WiDeBoDyEK &raquo;</TD></TR><TR><TD CLASS="quote">i want to see a how to on this,..or atleast someone write a quick howto </TD></TR></TABLE>
https://honda-tech.com/zerothread?id=267237
https://honda-tech.com/zerothread?id=597192
OmarR
Suspension & Brakes
Aug 13, 2008 12:14 PM
bag
17
Jun 14, 2006 11:09 AM
Halo
12
Jun 10, 2005 03:42 PM
suspendedHatch
Nov 24, 2004 10:15 AM
arcticblursx
Mar 29, 2003 01:00 AM
