wich pisotns for street use?
Old Dec 10, 2003 | 01:18 PM
birz's Avatar
Default wich pistons for street use?
wich brand of pistons is the best suited for street use? ross, arias, wiseco, JE, srp, CP, etc...
my setup here as follow:
B18B (only pistons will be changed+ a block guard, do i really need the block guard?)
transmission: GSR
turbo T25 @8psi (not planning to boost any higher than that)
440cc injector (talon)
fuel management: SMC+
MSD BTM
custom mandrel bent exhaust downpipe 2-3/4 and the line is 2-1/2
not sure wether i should go with 8.5cr or 9.0cr, I will bore out 81.5mm on the stock sleeves, obviously
my setup has been running for a year but now it smokes like hell, bad compression in piston #3 thats why im changing to forged pistons
Old Dec 10, 2003 | 01:22 PM
30psi Teg's Avatar
Default Re: wich pisotns for street use? (birz)
i say Wiseco I ran wiseco in my past engines I only now switched to ROSS because they are a lot heavier In my opion and I am running about 32psi or so.
Anyway I had great luck with Wiseco and they are realatvly cheap and they can handle a lot]
Old Dec 10, 2003 | 01:25 PM
birz's Avatar
Default Re: wich pisotns for street use? (30psi Teg)
but will the ross do the job for my setup?
Old Dec 10, 2003 | 01:27 PM
D3LSLO's Avatar
Default Re: wich pistons for street use? (birz)
this is always on here, do a search, BTW its almost entirely opinion.
Old Dec 10, 2003 | 01:28 PM
30psi Teg's Avatar
Oh yea ross will deffinatly do the job but for the cost Wiseco is a good choice.
For a high HP app. Ross are great but I think for your set up anything would really be fine even stock LS.
Old Dec 10, 2003 | 01:32 PM
birz's Avatar
Default Re: wich pistons for street use? (D3LSLO)
I did have search alot dont worry, but the questions asked are for different setup or diffenrent future project,,, here I'm talking about a simple reliable setup for street, not hardcore at all
oh and how about the CR and the block guard?
Old Dec 10, 2003 | 01:37 PM
30psi Teg's Avatar
CR I'd go with like between 9-10:1 really its just what you think 9:1 is going to be the safer way to go but 10:1 will give you the low end that a lot of people like.
anyway onto the blockgaurd I had one and didnt like it caaused my engine to over heat and ****. But some people have good luck with them.
Old Dec 11, 2003 | 06:31 AM
birz's Avatar
no other comments
Old Dec 11, 2003 | 06:42 AM
yellowturbo's Avatar
try to find piston who contain sillicon it it ... like the SRP you will be able to run them tigher so less noise and better sealling capacity when the engine will not be used full throttle...
leanlikeacholo
Apr 15, 2011 11:29 PM
roudiiboii
Nov 21, 2010 04:51 PM
LS-turboner
Dec 31, 2009 01:13 PM
Danal976
Jul 16, 2005 12:36 PM
yellow_jacket
Feb 23, 2004 08:51 AM
