Got $ 1200 dollars to spend need help on what to get for more power????
Old Sep 19, 2001 | 11:59 AM
AK94GSR's Avatar
Default Got $ 1200 dollars to spend need help on what to get for more power????
When you live in Alaska you get a dividend of about 2 grand each year and this year we get them on the 5th of OCT. I have a 94 gs-r with intake, dc header, skunk2 mani, and a type r intake cam. I already know that I am getting a tanabe RM exhaust, but need help on what else to get. Either it be port and polish job or for now just extrude hone my intake manifold and get the exhaust r cam with a b&m fuel pressure regulator and gauge. Need help on choosing. I am going all motor too
Old Sep 19, 2001 | 12:10 PM
D-SPEED's Avatar
Default Re: Got $ 1200 dollars to spend need help on what to get for more power???? (AK94GSR)
1200-500 or so for the RM....so 700 or so..... I would get the Set of R cams, some cam gears and a fuel pressure riser. then try to get it on a dyno
Old Sep 19, 2001 | 01:18 PM
Inigo Montoya's Avatar
Default Re: Got $ 1200 dollars to spend need help on what to get for more power???? (D-SPEED)
I would also inquire to your local shops on where you might get a port and polish done on the head and intake and throttlebody, if you are going all motor this will help, then weigh your options on getting the crank knife edged. but i think the port and polish would be good. also, do you have any management computers? v-tec controller, fuel controler and such? Also things to look at. Hmmmmm, new cam lobes, a chip for the computer, higher compression pistons. well tht is what i can think of for now, good luck!!!
Old Sep 19, 2001 | 01:22 PM
stick's Avatar
definitlely get vtec controller and cam gears and adj FPR
get rid of ur power steering and dyno tune u can easily hit 170hp to the wheels
if u have enough, port and polish and hi compression pistons like JDM ITR pistons
or USDM pistons
Old Sep 19, 2001 | 01:34 PM
AK94GSR's Avatar
Default Re: Got $ 1200 dollars to spend need help on what to get for more power???? (stick)
Yeah I am kinda of leaning towards sending my head out to be done. I have been talking with PYR and Skunk2 about getting it done. PYR quoted me 950 with springs and ret. and Skunk2 said about 800. Anyone else have any other suggestions.
Old Sep 19, 2001 | 03:12 PM
DelsolVtec18's Avatar
New User
ITR exhaust cam @300 so you have a full set
Camsprockets @200 so you can tune the cams
Ported T/B 64mm @200 so the t/b is matched to the skunk2 manifold
Fuel pressure riser @150 cause the sk2 manifold and t/b flows more air
Reprogram ecu @250 mugen/spoon/sk2/custom I take my gsr to 8500 on
stock internals no problem
Dyno @150 tune your sprockets/timing/fuel riser
i dont think you really need springs and retainers unless you are reprogramming your ecu to redline at 9000rpm or run FI...plus you have to take off and send your head to a shop and you will lose your car for like 2-4 weeks
[Modified by DelsolVtec18, 1:26 AM 9/20/2001]
[Modified by DelsolVtec18, 1:27 AM 9/20/2001]
Old Sep 19, 2001 | 03:17 PM
vtecvoodoo's Avatar
Future Texas Boy
Default Re: Got $ 1200 dollars to spend need help on what to get for more power???? (DelsolVtec18)
get atleast two strippers and throw a HUGE party! Charge 20 bucks at the door and you`ll make your $$$$$ back and have a kickass time
Old Sep 19, 2001 | 04:14 PM
AK94GSR's Avatar
Default Re: Got $ 1200 dollars to spend need help on what to get for more power???? (vtecvoodoo)
Thanks for the ideas and suggestions that helps me alot. I think I might take up the stripper party too. j/k
Anthony K's Avatar
New User
Somebody say Amen!
Old Sep 19, 2001 | 04:30 PM
redteg1's Avatar
Default Re: Got $ 1200 dollars to spend need help on what to get for more power???? (GS-R916)
get nitrous
Old Sep 19, 2001 | 04:33 PM
AK94GSR's Avatar
Default Re: Got $ 1200 dollars to spend need help on what to get for more power???? (redteg1)
Nah nitrous would be nice easy way, but I like the all motor route.
Old Sep 19, 2001 | 05:02 PM
FAST94GSR's Avatar
New User
Headwork, the difference is night and day, or save up for a turbo
Old Sep 19, 2001 | 05:19 PM
B18C-RnVA's Avatar
New User
Default Re: Got $ 1200 dollars to spend need help on what to get for more power???? (FAST94GSR)
yeah i say save up for the turbo at 1200.00 you almost half way there
Old Sep 19, 2001 | 05:48 PM
thefungus's Avatar
New User
$1200 = a months rent for a nice studio in soCal.
[Modified by theFungusAmongus, 2:50 AM 9/20/2001]
Old Sep 19, 2001 | 06:03 PM
ALF's Avatar
ALF
Default Re: Got $ 1200 dollars to spend need help on what to get for more power???? (B18C-RnVA)
Ditto.
Personally, I'd get my engine rebuilt with stronger internals.
[Modified by Dozed, 10:04 PM 9/19/2001]
Old Sep 21, 2001 | 09:34 AM
AK94GSR's Avatar
Default Re: Got $ 1200 dollars to spend need help on what to get for more power???? (Dozed)
Has anyone Extrude Honed they're intake manifold???
Old Sep 21, 2001 | 09:35 AM
GSRwBOOST's Avatar
buy a turbo with the money.. and an intercooler.. then start piecing togetehr the rest of the turbo kit over the next several months.. and your all set for power!
Old Sep 21, 2001 | 11:39 AM
Tanner's Avatar
New User
Default Re: Got $ 1200 dollars to spend need help on what to get for more power???? (GSRwBOOST)
Yeah thats what I would do.. or just save it and buy a kit... there is always a good group buy on some kit.. or hit up ben@importparts.com...
Old Sep 21, 2001 | 03:55 PM
Mr. Softee's Avatar
Default Re: Got $ 1200 dollars to spend need help on what to get for more power???? (GS-Racer01)
id go with new pistons + install then cam gears / tuned. 20whp easily.
-sam
Old Sep 21, 2001 | 03:58 PM
Strider Turbo's Avatar
Wait one more year and get Turbo. The best investment for speed ever. It may require more then that but if work is paying for most of it GO FOR IT!!!!
jaref9
Jun 27, 2009 11:35 AM
2002civicd17
Honda Civic (2001 - 2005)
17
Nov 22, 2007 06:25 PM
non vtec
Oct 21, 2002 04:26 PM
