Rear trailing arms: Difference between DC2R and DC2/4?
Old Dec 8, 2003 | 08:23 AM
743power's Avatar
Default rear trailing arms differences amongst DC2r and DC2/4?
Can any of you R owners verfiy that the rear trailing arms are the same between a gsr/ls and a type R? I remember hearing that the type R are more reinforced, and I told someone that, but I don't want to give out false information. Thanks.
Old Dec 8, 2003 | 08:27 AM
mstewar's Avatar
Default Re: rear trailing arms differences amongst DC2r and DC2/4? (743)
ITR part #s: 52370-ST7-R02, 52371-ST7-R02
GSR/LS part #s: 52370-ST7-G91, 52371-ST7-G91
so, i would assume they are in fact different.. never had the two side by side though..
Old Dec 8, 2003 | 08:45 AM
743power's Avatar
Default Re: rear trailing arms differences amongst DC2r and DC2/4? (mstewar)
on me for not checking part #'s. Thanks man.
Old Dec 8, 2003 | 12:01 PM
Nextelbuddy's Avatar
i have a bent type r rear passenger side trailing arm. i have a set of rear gsr brakes in my garage with good trailing arms. i would like to swap over the 5 lug hub assembly to the gsr trailing arm. i know it will bolt up but since the gentleman above stated that gsr and type r have different part numbers that worries me. what kinda of problems will i runinto haveing a type r trailing arm on teh driver side with 5 lug hub assembly and a gsr trailing arm on the passenger side with 5 lug assembly? any help please i need to drive to work its my only car and i took the day off tommorrow to fix it. i need to know if i have to buy a type r trailing arm or can i use my good gsr one.
Old Dec 8, 2003 | 12:30 PM
mstewar's Avatar
Default Re: rear trailing arms differences amongst DC2r and DC2/4? (nextelbuddy)
switch them both, or don't switch either of them..
a new ITR trailing arm isn't actually all that expensive at the dealer.. consider this as an option..
can you even put the 5 lug assembly onto a gsr trailing arm? I can't really think of why not, but at the same time it doesn't jive that it would work..
Old Dec 8, 2003 | 12:46 PM
yea i know lots of people that swapped over the 5 lug assembly to the 92-95 civic trailing arm. all they ahd to do was remove the drum assembly and bolt on the 5 lug assembly. i know it will bolt on no problemto the gsr trailing arm. my only concern why would gsr and type r be different. they are both DC chassis. what is the difference. someone here has to know. the only difference i can think of would be maybe stiffer bushings or possibly maybe the metal used to make the trailing arm might be different like lighter or stiffer. anyone?
Old Dec 8, 2003 | 01:30 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nextelbuddy &raquo;</TD></TR><TR><TD CLASS="quote">yea i know lots of people that swapped over the 5 lug assembly to the 92-95 civic trailing arm. all they ahd to do was remove the drum assembly and bolt on the 5 lug assembly. i know it will bolt on no problemto the gsr trailing arm. my only concern why would gsr and type r be different. they are both DC chassis. what is the difference. someone here has to know. the only difference i can think of would be maybe stiffer bushings or possibly maybe the metal used to make the trailing arm might be different like lighter or stiffer. anyone?</TD></TR></TABLE>
anyone?
NXSpoon
Aug 7, 2006 12:55 AM
the_illest_soldier
Apr 4, 2005 04:27 AM
k20z
Feb 23, 2005 11:19 PM
bgod
Sep 26, 2004 04:32 PM
