Q: will high flow cat throw a code on 99-00 Si..?
Old Dec 7, 2003 | 10:08 PM
Downey's Avatar
Default Q: will high flow cat throw a code on 99-00 Si..?
installing a dc jdm 4-1, carsound high flow cat and Greddy evo exhaust on 99-00 Civic Si soon. will it throw a code for o2 sensor or the catalyst system? anyone have any experience with this? any way of getting around the CEL other than going to an OBD-1 computer?
thank you for any help at all
-Graham
Old Dec 7, 2003 | 10:28 PM
Shawn C's Avatar
In The Garage
Default Re: Q: will high flow cat throw a code on 99-00 Si..? (Downey)
it could possibly throw a code, since a really high flow cat won't change much between O2 sensors. a lot of people use an O2 simulator. let me know if you need one. I'll let you know tomorrow how much, since my friend has a few at his shop
Old Dec 7, 2003 | 10:29 PM
Hybrid96EK's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Downey &raquo;</TD></TR><TR><TD CLASS="quote">installing a dc jdm 4-1, carsound high flow cat and Greddy evo exhaust on 99-00 Civic Si soon. will it throw a code for o2 sensor or the catalyst system? anyone have any experience with this? any way of getting around the CEL other than going to an OBD-1 computer?
-Graham
No, it won't toss a code. Never did on my 99 Si and I ran a similar setup. The only time when I got the CEL was when I put in the test pipe with the turbo kit. That took about 3 days before the light came on. As far as getting rid of it, use an O2 simulator.
Old Dec 7, 2003 | 10:34 PM
Downey's Avatar
thanks alot for the quick response guys!
Old Dec 7, 2003 | 10:42 PM
clm's Avatar
clm
It'll throw a code if you don't have the O2 conencted to the converter (not all come with an O2 bung) or a simulator.
Old Dec 8, 2003 | 05:23 AM
SOHC_MShue's Avatar
my friend had one on his si and it threw a code. I am getting the code from my testpipe and it comes on very very frequently. Thank god I'm going obd1 soon.
Old Dec 8, 2003 | 10:56 AM
Hybrid96EK's Avatar
Default Re: Q: will high flow cat throw a code on 99-00 Si..? (SOHC_MShue)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SOHC_MShue &raquo;</TD></TR><TR><TD CLASS="quote">my friend had one on his si and it threw a code. I am getting the code from my testpipe and it comes on very very frequently. Thank god I'm going obd1 soon. </TD></TR></TABLE>
There is no question that a test pipe WILL throw a code on an OBD-II vehicle. He was asking about a high flow cat, which should not be throwing any codes.
Old Dec 8, 2003 | 11:27 AM
chads's Avatar
Default Re: Q: will high flow cat throw a code on 99-00 Si..? (Hybrid93Eg)
if you install a DC header it will also throw a code
Old Dec 8, 2003 | 11:39 AM
Hybrid96EK's Avatar
Default Re: Q: will high flow cat throw a code on 99-00 Si..? (FlamencoEsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by FlamencoEsi &raquo;</TD></TR><TR><TD CLASS="quote">if you install a DC header it will also throw a code </TD></TR></TABLE>
Incorrect. Ran a DC 4-1 on my Si for quite some time with 0 problems. There is NO reason a code should come from a carb legal header, much less ANY header that retains the O2 bung.
Old Dec 8, 2003 | 11:43 AM
SOHC_MShue's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Hybrid93Eg &raquo;</TD></TR><TR><TD CLASS="quote">
There is no question that a test pipe WILL throw a code on an OBD-II vehicle. He was asking about a high flow cat, which should not be throwing any codes.</TD></TR></TABLE>
i said that my friend had a hi-flow on his si and it threw a code .
2000CX's Avatar
with a simulator in place...will the car run normal or will something like the a/f still be off without a real sensor in the exhaust stream adjusting everything? i have been running for some time with no secondary hooked up and i would LOVE to see that cel go away.
Old Dec 8, 2003 | 11:44 AM
Hybrid96EK's Avatar
i said that my friend had a hi-flow on his si and it threw a code . </TD></TR></TABLE>
Saying your friend had "one" was not too clear, so I am sorry for reading it incorrectly. There was talk of both test pipes and high flows, so "one" was not exactly specific.
Old Dec 8, 2003 | 11:46 AM
Hybrid96EK's Avatar
Default Re: Q: will high flow cat throw a code on 99-00 Si..? (2000CX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2000CX &raquo;</TD></TR><TR><TD CLASS="quote">with a simulator in place...will the car run normal or will something like the a/f still be off without a real sensor in the exhaust stream adjusting everything? i have been running for some time with no secondary hooked up and i would LOVE to see that cel go away.</TD></TR></TABLE>
As far as I know, it will run just like normal. I have not personally had any experience with these products myself, so I cannot gaurantee it.
Old Dec 9, 2003 | 04:48 AM
SOHC_MShue's Avatar
hey Downey what happened to your hatch?
Old Dec 9, 2003 | 07:48 AM
LIFER's Avatar
probably need an o2 stimulator.... i did this on a friend's ex and that fixed the prob.
Old Dec 9, 2003 | 02:42 PM
kamaleon's Avatar
Default Re: Q: will high flow cat throw a code on 99-00 Si..? (LIFER)
lets see... my experienses:
96 civic with carsound high flow cat.. --&gt; no codes
96 civic with no cat but 02 still hooked to the harness --&gt; no codes
as soon as i disconect teh 02 from the wire harness then it throws a code.
maybe my car is special? nahhhh
Old Dec 9, 2003 | 02:56 PM
psileepR's Avatar
New User
Default Re: Q: will high flow cat throw a code on 99-00 Si..? (kamaleon)
the sole purpose of the second O2 sensor in the cat of obd2 cars is to test that the cat is doing its job and leaning out the mixture within a certain range.
so... if your high flow cat sucks and doesnt do its job within set parameters you will get an O2 sensor code.
i have not had any CELs with my high flow carsound cat on my obd2 civic.
Old Dec 9, 2003 | 03:31 PM
SD_EM1's Avatar
i ran an identical (i ran the OEM rather than the DC) setup on my car and never had a CEL of any sort occur.
Incorrect. Ran a DC 4-1 on my Si for quite some time with 0 problems. There is NO reason a code should come from a carb legal header, much less ANY header that retains the O2 bung.</TD></TR></TABLE>
i believe he was asking about the dc jdm header which isn't carb legal, not the usdm version
Old Dec 9, 2003 | 04:21 PM
TwistedSI's Avatar
I've got a DC 4-2-1 on my SI and I've never thrown a code due to it.
Old Dec 9, 2003 | 05:25 PM
SpoonEK2's Avatar
Default Re: Q: will high flow cat throw a code on 99-00 Si..? (TwistedSI)
Random Tech cat throws a code on my Si. CODE 67...for the last 30,000 miles. I think i'm going to get a carsound. When I put a stock cat in, the code resets.
Old Dec 17, 2003 | 01:35 PM
chads's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TwistedSI &raquo;</TD></TR><TR><TD CLASS="quote">
I've got a DC 4-2-1 on my SI and I've never thrown a code due to it.</TD></TR></TABLE>
thats weird i wonder why mine gave me a code???? i have stock everything exept a dc header...
Old Dec 21, 2003 | 11:22 PM
mogz's Avatar
So which high flow cats are you guys using that does not through a CEL on an OBDII? I have a 00 GSR and am interested in getting a high flow cat.
1SloNeon
11
Jul 5, 2008 09:45 AM
Midori Green
12
Oct 13, 2007 05:37 PM
nutball72
Aug 10, 2007 03:05 PM
yee SERIOUS
Sep 14, 2005 07:17 PM
Two_K Si
Oct 13, 2004 08:32 PM
