CEL CODE 67 or P0420
Old Sep 13, 2005 | 04:37 PM
yee SERIOUS's Avatar
Default CEL CODE 67 or P0420
P0420 Catalyst System Efficiency Below Threshold
i got a new high flow cat about a month ago when i installed my turbo kit. you guys think the o2 sensor is bad? the high flow cat is a magnaflow and the o2 sensor is position after the cat.
this seemed to happen after i installed my a/f guage i think. i redid the wiring, and about after an hour of driving, the CEL will return. so i don't know what it could be. the a/f guage works fine. i have no idea what else it could be.
Old Sep 13, 2005 | 05:57 PM
N20civicB18's Avatar
Default Re: CEL CODE 67 or P0420 (LiTtOGPiMp)
you hooked your AF guage up to the upstream o2 correct?
It is possible that your cat moniter is bad but it also is possible that the high flow cat does not perform like the factory cat.
Old Sep 13, 2005 | 06:49 PM
allstokhonda's Avatar
Well, I know on an My Evo VIII, Even with some types of highflow cats.. it'll still throw the 420 code. I just use the simple spark plug anti-fouler trick. to trick the rear o2 from gettin upset. I don't even run a cat on my car. It's just striaght 3" pipe from the turbo Back. If you wanna try the anti-fouler trick. just pm me or reply back. It's really simple and only take about 10mins to do... good luck..
-Chad-
Old Sep 13, 2005 | 08:51 PM
Jared's Avatar
normally 02 sensors dont set the p0420
the ecm logic for comparing front o2 signal to rear o2 signal doesnt like the amount of similarity between the two caused by your high flow cat.
Old Sep 14, 2005 | 08:35 AM
Default Re: CEL CODE 67 or P0420 (N20civicB18)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by N20civicB18 &raquo;</TD></TR><TR><TD CLASS="quote">you hooked your AF guage up to the upstream o2 correct? </TD></TR></TABLE>
i hooked it up to the ecu white wire. C16 on obd2b - ph02s - promary heated 02, sensor-1
i used this diagram http://technet.ff-squad.com/wiring.obd2b.htm
how would i do this foul washer trick? i was thinking about replacing the o2 sensor to see if it just went bad or not. i have no other idea what it could be. i doubt the cat would go bad within a month when i barely and rarely push my car.
Old Sep 14, 2005 | 02:17 PM
i was wondering if you guys think this will work
http://www.highrevmotorsports....=1108
casper's o2 simulator. it'll tell the ecu the cat is working fine, but wouldn't this give my a/f guage the wrong reading?
Old Sep 14, 2005 | 07:17 PM
anyone know if a SIM would throw off my a/f guage?
Crazyxc2448
Mar 25, 2010 03:56 PM
elpiar
May 8, 2005 09:37 AM
Two_K Si
Oct 13, 2004 08:32 PM
