B20Vtec fuel pressure
Munkyw3rkz.webs.com
i want to know what fule presure you guys are running. my friend has that set up adn its reading 36-38psi and is running the stock 99 si ECU and is throwing a code 45. if i raise the fuel pressure couldnt it get rid of it? i want to see if he can go that way b 4 swaping to a P28
Munkyw3rkz.webs.com
yea i had the same thoughts about running a P28 with the convert harness with a custom set up for it kuz its throwing a code 45 right now
Your prolly running waaaaay lean. Check your plugs and see what they tell you. Bump your fuel pressure up to 45psi. I have my B20 no tec @ 43 right now... Runs alot better then at 38....
Good Luck
Blaze
Good Luck
Blaze
Munkyw3rkz.webs.com
i just cehck out the car and its at 38psi but hte car is throwing a code 45 which is rich in fuel? this doesnt make sence
Munkyw3rkz.webs.com
been 2 days and no check light...i got rid of the code!...but still need to get a P28 to tune the car its really lacking in power
95hatchfire
Jan 12, 2005 10:52 AM
