Early Rev Limit in D16z, but no CEL...?
Old Dec 5, 2003 | 10:13 AM
polymath's Avatar
Default Early Rev Limit in D16z, but no CEL...?
Got a freshly rebuild D16z...no check engine light, no oil light. Engine hits the limiter at 5200 rpm.
Any ideas as to why it would act as if it were in safe mode, yet not show a CEL?
Old Dec 5, 2003 | 11:08 AM
blackcivicsi's Avatar
Default Re: Early Rev Limit in D16z, but no CEL...? (Coyote1800cc)
Hake sure you MAS (mass air sencor) is pluged up and works properly. I know that when it is left unpluged or is bad it will case an early rev limiter
Old Dec 5, 2003 | 12:04 PM
MIRRAdekhtc's Avatar
Default Re: Early Rev Limit in D16z, but no CEL...? (blackcivicsi)
or your ECU....maybe its a cx/dx ecu
Old Dec 7, 2003 | 04:35 PM
polymath's Avatar
Its a P28 ecu...funny thing is, if I plug in the Dx ecu, it rev limits even earlier.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blackcivicsi &raquo;</TD></TR><TR><TD CLASS="quote">Hake sure you MAS (mass air sencor) is pluged up and works properly. I know that when it is left unpluged or is bad it will case an early rev limiter</TD></TR></TABLE>
Interesting...I have another map sensor, so I'll check it out.
Old Dec 7, 2003 | 06:17 PM
Jimmy's Avatar
Global Moderator
Could your CEL be burnt out?
Old Dec 7, 2003 | 06:18 PM
D-Man's Avatar
could be the ignition ignitor inside the distributor
Old Dec 7, 2003 | 07:03 PM
CleenSi
Guest
Posts: n/a
Default Re: Early Rev Limit in D16z, but no CEL...? (MIRRAdekhtc)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MIRRAdekhtc &raquo;</TD></TR><TR><TD CLASS="quote">
or your ECU....maybe its a cx/dx ecu</TD></TR></TABLE>
yea what he said
Old Dec 8, 2003 | 11:53 AM
doublejz's Avatar
Default Re: Early Rev Limit in D16z, but no CEL...? (CleenSi)
check your map and tps sensor, could have them switched. I did that once
Old Dec 8, 2003 | 08:20 PM
polymath's Avatar
Default Re: (USDMDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 &raquo;</TD></TR><TR><TD CLASS="quote">Could your CEL be burnt out?</TD></TR></TABLE>
No it works...it comes on as the fuel pump primes.
It is definitely an EX ecu...unless there are a set of dx ecus out there marked "P28".
I'll try the ignitor next...I just tried the map sensor from a known working car, at it started to rev-limit at 4.5k.
Old Dec 8, 2003 | 08:26 PM
polymath's Avatar
Default Re: Early Rev Limit in D16z, but no CEL...? (doublejz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by doublejz &raquo;</TD></TR><TR><TD CLASS="quote">check your map and tps sensor, could have them switched. I did that once </TD></TR></TABLE>
I'm sure that's not it, cause it was a Dx originally that had the map sensor on the firewall, so the plugs aren't coming from the same loom.
I'll go ahead and varify everything at the ECU, though.
Old Dec 8, 2003 | 08:52 PM
mastarolla's Avatar
if you have any sort of VTEC control wired...check that as well. My e-manage made my rev cut at like 4000 because of a VTEC solenoid malfunction??
Old Dec 9, 2003 | 01:11 PM
polymath's Avatar
Default Re: Early Rev Limit in D16z, but no CEL...? (mastarolla)
Its basically just a DX that got transformed into an EX.
One thing I did do, was rip all the internals from the DX distributor and put them into an EX casing to mount it. I've swapped parts between sohc and dohc distributors, so I didn't envision a problem.
sonno
Engine Management and Tuning
Apr 19, 2014 01:41 PM
the king.
Jan 10, 2009 05:42 PM
Damon Reeves
Jan 29, 2008 06:28 PM
EK H47CH
Nov 14, 2006 12:43 PM
Quade
Nov 24, 2005 12:15 PM
